8lb lower or 6 lower & 2 upper combo
Old Oct 26, 2003 | 03:18 PM
flying brick's Avatar
I just wanted see if anyone is running an 8lb lower or 6lb lower and 2 upper combo. I am currently running a 4lb lower and 2lb upper on a stock short block and considering adding the 6lb lower, however do not want to compromise for just a little gain. Also any times with these combo's and longevitiy? Thanks in advance!
Old Oct 26, 2003 | 03:42 PM
mecca's Avatar
I plan on running a 9.5" Lower, and 2.77" Upper on my truck, but then again I have a built bottom end...
-Mike
Old Oct 26, 2003 | 04:02 PM
Fast Gator's Avatar
I've been running a 6 lber on the bottom of a stock bottom-end for awhile now.
But you know the saying...........
Old Oct 26, 2003 | 04:12 PM
I wish I had a built bottom end but do not. If I did I would not be so concerned. Fast Gator, I was not going to switch just to a 6lb lower, but run a 6lb lower with a 2lb upper. I am using an REM 2.77 upper and a 4lb lower currently. I am thinking that the gain may not be worth the risk. Just wanted to see if anyone was having luck with this set-up.
Old Oct 26, 2003 | 04:21 PM
s.cal L 2's Avatar
Ive been running a 8# lower, no problems yet did feel more low end torque.
Old Oct 26, 2003 | 06:37 PM
ShaneMcKenna203's Avatar
how are you running with the 4# lower and the 2# upper? What other mods do you have? Thanks, Shane
Old Oct 26, 2003 | 08:35 PM
Hey Shane, my best 1/4 mile time is a 12.48 @ 108 and 1/8 mile 7.86 @ 87. The 12.48 was under warmer conditions and a 1.77 60' in FFW in Ennis. I have all standard stuff except headers or catback meaning chip, pulley, TB, ftvb, high flow cats, elec fans, ported pleneum, traction bars. I am still running the stock 3.55 gears.
Old Oct 26, 2003 | 08:46 PM
Fast Gator's Avatar
I forgot to add Iam running an extra 1 lber on top
But I run the large JDM heat exchanger with Spal fans to "help" dissipate all the heat Iam generating with the Eaton. I might not be efficient, but I can bang out 11's all day long on my stock block,stock eaton and stock converter all day
