Phenolic spacer
Old Oct 25, 2003 | 02:21 PM
flying brick's Avatar
Phenolic spacer
I purchased one but have not installed it yet. Keep reading some positive and negative stuff about it which I know is typical of any part. Just wanted to see how many are using it, gains or loss they had and if there was any clearance issues. Thanks in advance for you time.
Old Oct 25, 2003 | 02:25 PM
Probleminfected's Avatar
only gain if you are using the eaton and not the KB
no clearance problems unless you use a 1" and not the standard 1/2"
keeps the plenum cooler
Old Oct 25, 2003 | 03:26 PM
Thanks for your reply probleminfected. I am using the stock eaton and it is a 1/2" spacer.
Old Oct 25, 2003 | 03:37 PM
Odin's Wrath's Avatar
Just installed mine Wednesday. No problems with the install. It does keep the the upper plennum cooler.
Old Oct 25, 2003 | 03:41 PM
l-menace's Avatar
it works as it is designed to.
the intake is cool to the touch ALL the time.
Hot summer days, the intake is ambient temperature, no where nearly as hot as the engine though
Old Oct 25, 2003 | 07:17 PM
dealerjim's Avatar
I have a JDM phenolic spacer installed on my Kenne Bell and it has worked great for over 3500 miles now. I think alot of the problems people are having are due to faulty installation.
Old Oct 25, 2003 | 07:32 PM
promodlightning's Avatar
The phenolic in combination with removing your EGR will keep your plenum even more cooler....
Old Oct 25, 2003 | 07:40 PM
l-menace's Avatar
dumba$$ you just voided your Kenny Bell warranty!
Old Oct 25, 2003 | 08:08 PM
dealerjim's Avatar
I'm as worried about a warranty on a $3000 blower as I was a $30,000 truck when I put a built block in it with every bolt on you can think of with only 20,000 miles. IMO If you can't afford to play the game, don't put your chips on the table. If it breaks I'll buy another one.
Old Oct 25, 2003 | 08:19 PM
shawnting's Avatar
So now you guys have the spacer, do you still ice down the plenum at the track between runs???
Old Oct 25, 2003 | 08:28 PM
SVT F15O's Avatar
You are the man! -Mat-
Old Oct 25, 2003 | 08:51 PM
ICULOKN's Avatar
Exactly!!! Right on brother!
Old Oct 25, 2003 | 09:32 PM
03LightninRocks's Avatar
This was my experience with it also. I run a 6 lb lower and my plenum use to get so hot after a pass or two you could fry an egg on it.
With the spacer it is only warm after a pass or two. I did not dyno before and after, but the cooler plenum seems like it would translate into a cooler air charge. I am happy with mine.
Rocks
Old Oct 25, 2003 | 09:40 PM
whip's Avatar
It works! I did a bunch of testing with a very high $$ infa red temp gun. I forget actual #'s but the plenum dropped like 20-30 degree's.
Old Oct 25, 2003 | 09:41 PM
blown318's Avatar
