Back from track, help, whats wrong??
Old Oct 23, 2003 | 05:07 PM
Rob_02Lightning's Avatar
Originally posted by SlowSVT95
You liar...
"After major testing this Theroy I can to find mine will absolutely"
So you were testing "this the roy" ???
Ok I admitt it, I spelled it wrong
"THEORY" is what I meant, not The Roy
Jubelands
Sorry I didn't realize you were in CA, using that low of octane.
Like I said, some ping, some dont, unfortunatly you are not gonna be able to get full potential and performance due to that
If anyone can help you, Sal sure can
GOOD LUCK
Old Oct 23, 2003 | 05:22 PM
SlowSVT95's Avatar
Jubelands
GOOD LUCK
As long as you admit it
Old Oct 23, 2003 | 05:52 PM
Suavy's Avatar
With JLP's stage 2 kit which includes ram air, superchip flip chip and trany line mod I was making consistant 13.5's @ 105 mph with a 1.9 60 ft.
Just a little info for you, that was with no pulley.
Peace, suavy
Old Oct 23, 2003 | 06:00 PM
Fast Gator's Avatar
Old Oct 23, 2003 | 07:47 PM
mikes2lights's Avatar
Lightbulb
sorry to hear ur times, you should be in the 12s
im all stock with just a line mod
13.6 all day
2.0 60'
Old Oct 23, 2003 | 07:49 PM
SlowSVT95's Avatar
13.6 all day
2.0 60'
2.0 60'??? Damn my gen 1 gets 2.1s...
Old Oct 23, 2003 | 08:07 PM
1.8's or 1.9 on F-1's at my Local Track
1.7's on the slicks there (Long Island MotorSports Park)
1.6 on slicks everywhere else, Eng Town, Cecil, Etc....
It is clearly all about the first 60ft Jubelands
get that down to a 1.6 - 1.8 and you got your 12 sec run
Try less air in the rear and more in the front like people are saying
Keep it parked for hours if possible before racing
I would get a second more aggresive tune from Sal,
then on race day use that program, simply get there with less than 1/4 tank of gas and spring for $30.00 in racing fuel,
YOU'LL GET YOUR 12's and it'll be well worth the cost of racing fuel (plus you'll need it to run a little more timing)
With a little more WOT timing, it'll pick up major ET.....
Old Oct 23, 2003 | 08:40 PM
Jubelands's Avatar
Old Oct 23, 2003 | 09:08 PM
Remember your mixing it with crappy 91 octane,
so the overall octane level will be less than what you put in
Plus Sal will prob not recommend running that super hi octane.
I know at English town I was told not to use the super hi
octane racing fuel and stick with the regular racing fuel.
Dont remember the Octane, 102 / 104 ??? Something like that
Old Oct 23, 2003 | 09:23 PM
03LightninRocks's Avatar
Originally posted by Jubelands
Well i'm pretty sure it is not the fuel filter because i changed it a couple of hundred miles ago. What should i do about the tune, should i go back to the dyno tune place or should i send my dyno graph and chip to sal and see what he could do?
What if my truck just can't handle more timing. It was actually pinging before this tune and somewhat still does on tip in at low RPM's on the freeway.
How can i find out if something is wrong with my fuel system?
All my tunes have been on 91 octane pump gas. Is it possible to be in the 12's with a 91 octane?
I may be mistaken but I believe there is a tuner out in Cali named Danny Swanson. You may want to take a field trip to him and have the tune done by someone closer to you than the great white north. It may be quicker than sending chips back and forth until you blow your motor.
Rocks
