Engine Donation
Old Oct 22, 2003 | 11:33 AM
builtfordfast's Avatar
Engine Donation
Wish it was donated to me but, NOT!
My wife(Sandi) works at the local University in an Automotive Research and Development program called Auto21
and Ford donated the 5.4 S/C engine to the shop for the students to play with.
From the looks of the engine, it has a black blower and plenum, no SVT marking on the S/C casing, so I am thinking this was probably for an HD F150. It has a March 03 build date. Should have checked the size of the blower snout pulley.
What I need to do now is convince them that it would be a great learning experience to swap heads with me. Hehe!
Heres a couple of pics.
Old Oct 22, 2003 | 11:47 AM
MaxPower's Avatar
So THAT'S where that little hole in the bottom of the intake (filled with oil) goes! ...and where that d@mn line T's off to from the passenger side PCV valve...
Line highlighted in yellow. Drain hole circled.
The bottom of the intake, just under the intercooler. Note the puddle of oil and the opening:
interesting...
Old Oct 22, 2003 | 12:10 PM
ken800's Avatar
That is really interesting indeed. It certainly shows ford knows the oil issue and has a "fix" to let the oil run back down into the case. Why not change the oil capture kits to not capture, but T into the return line instead?
Old Oct 22, 2003 | 01:45 PM
I figured it would be interesting to see some things you just can't see when it's in the engine compartment,especially at the back half.
Here's a couple more....
Back..High
Back..Passenger..High
Back..Passeger..Coilpacks
Old Oct 22, 2003 | 01:46 PM
And just a few more...
Front..Driver..High
Front..Driver..Low
Front..Driver..Engine tag
...Dats all Folks !!!
Old Oct 22, 2003 | 02:57 PM
Dan_03Lightning's Avatar
Maple syrup, french toast, hockey and our 5.4 SC 330 cu.in. kick butt power plant - I knew there was a reason I liked Canadians! (well besides being one)
Great shots, Dave - is that University of Windsor? Spent many a night casing skirt and avoid classes in the late eighties there.
D-Day
Old Oct 22, 2003 | 03:07 PM
D-Day
You got it D-Day. U. of W.
Don't forget to give me a call if you ever here for a hometown visit.
Have a good one Dan !
....Dave
Old Oct 22, 2003 | 03:14 PM
simmy711's Avatar
DAMN! That's where my swivel head went!
Cool pics.
Old Oct 22, 2003 | 03:56 PM
ShaneMcKenna203's Avatar
Those heads are huge!
I didnt know our heads were that big...
Man if I had my motor out of my truck like that I couldnt even imagine the things I'd do...
Everything would be so much easier to install. The spacer would go right on. Long tubes would be a brease. Plugs and blower swap wouldn't be that bad. The main thing that cought my eye was the stock manifold and how easy long tubes would be to just swap out while the motor is out... Thanks for the pics, Shane
Old Oct 22, 2003 | 06:30 PM
superfords's Avatar
Re: Those heads are huge!
It's as easy as 1.... 2.... 3....
1
2
3
click here for LOTS more Lightning repair pictures!
later,
chris
Old Oct 22, 2003 | 06:32 PM
superfords's Avatar
1... 2... 3... more!
new head and a pulley swap to boot!
Old Oct 22, 2003 | 06:41 PM
denny0328's Avatar
damn!! thats the kinda garage i need!
Old Oct 22, 2003 | 07:29 PM
PBGas's Avatar
Very cool pictures, Gents!
Thx so much for sharing!
Paul G.
Old Sep 1, 2004 | 08:51 PM
Fast Gator's Avatar
steal that motor and put it in your riding lawnmower
Old Sep 2, 2004 | 02:03 AM
ND4SPD's Avatar
Damn Superfords, that is crazy how you take the cab off, how long does it take you guys to pull a motor?
