crank case breather
Old Oct 21, 2003 | 08:10 PM
rodcobra's Avatar
crank case breather
do i need one ,and what does it do for our trucks
Old Oct 21, 2003 | 08:12 PM
soap's Avatar
Re: crank case breather
Does nothing if mounted on the driver side..........
You don't need one.
--Joe
Old Oct 21, 2003 | 08:14 PM
Speedin Bob's Avatar
From: On the side of the Road attempting to explain 135 miles per hour
IMHO
dont mess with them.
What do they do?
Throw lean codes, that's what.
Just because the Check Engine light doesn't illuminate does NOT mean the codes aren't there.
AutoTap OWNZ!
Bob
Old Oct 21, 2003 | 08:15 PM
soap's Avatar
Re: IMHO
Originally posted by Speedin Bob
AutoTap OWNZ!
Bob
--Joe
Old Oct 21, 2003 | 08:21 PM
99svtlightning's Avatar
I have a breather cap and I don't have lean codes. I keep a Hellion attached at all times, no pending codes either.
Old Oct 21, 2003 | 08:24 PM
LIGHTNINROD's Avatar
I had three of them. They dripped oil onto the engine They're gone!
Dan
Old Oct 21, 2003 | 08:36 PM
Patrick_PDX's Avatar
Your question has many different answers. There are SO many different opinions on this subject.
The reason people started using the breather is to cut down on the amount of oil entering the intake manifold.
If you don't mind your intercooler being caked with oil, then you don't need one.
The only 100% effective way to get rid of the oil problem is to cap off the PCV system and vent the valve covers with breathers.
However..... most people prefer having at least a partially functional PCV system..... so that is the purpose of using breathers or different PCV valves, or oil separaters .....etc.
BTW, PCV valve part # EV98 installed in place of your original will solve at least 50% of the oil in the intake problem. That is probably good enough for most folks.
Old Oct 21, 2003 | 08:52 PM
rodcobra's Avatar
I have one pvc kit on the left side .I just ordered the one for the right side ,would a breather cap help more
Old Oct 22, 2003 | 02:45 AM
echo5oscar's Avatar
Patrick_PDX, is that a ford part number (EV98)and what is the difference from the stock one?
Old Oct 22, 2003 | 03:07 AM
99 SVT Bolt's Avatar
Old Oct 22, 2003 | 04:18 AM
EV-98-B PCV valve. Install it in place of the original on passenger side.
This is a one way valve. It closes while under boost. This prevents boost from lower intake adding to the crankcase pressure that is already there from ring blowby, thus resulting in less oil being sucked up though the tube on the driver side and into the rubber intake boot just in front of the throttle body.
This valve will take care of alot of the oil in the intake problem.
The stock PCV valve flows both ways..... why? I don't think anyone knows that answer.
BY the way...... there is really no way you can have a fully functioning PCV system and NOT have some oil find it's way into the intake system.
Some people swear by the Oil separaters, but really.... who wants to open up the hood every 300 miles or so and drain it ?
Old Oct 22, 2003 | 09:50 AM
Cali L's Avatar
Have plugged pcv and pass. breather. No codes thrown here either, none stored (just had is scanned by Ford). Only problem is the mess on the motor. Mine's not a show truck
BD
Old Oct 22, 2003 | 10:11 AM
easterisland's Avatar
I have breathers on each valve cover. I don't get any codes either.
Old Oct 23, 2003 | 12:52 AM
rodcobra's Avatar
I'm getting my L tuned friday, and guess i will get a breather for it.I hope it doesn;t leak oil
