6# lower only making 12 psi????
Old Oct 20, 2003 | 10:25 PM
whtlight01's Avatar
Angry 6# lower only making 12 psi????
Sunday i put Autometer Lunar gauges in my truck...take it for a test ride at night at WOT it only showed 12 psi!! what the hell. I have a 6# lower, cai and all the other bolt ons except exhaust. I checked the tubing for the gauge and no kinks. I dynoed 427 and 533...and went 12.5 in the 1/4 Truck also doesnt seem as fast what could it be any ideas?
Old Oct 20, 2003 | 10:30 PM
Suavy's Avatar
Take a look at the snout on your supercharger ans see if there is any belt dust you could be slipping.
Peace, Suavy
Old Oct 20, 2003 | 10:36 PM
NTIMD8's Avatar
If you ran 12.5 then you are most likley seeing the 14-15 psi you should be. Did you not have the Dyno hooked up to see how much boost you where running?
My guess is a problem with the gauge, but thats just my 2 cents though.
If not then you may have a slipping belt as mentioned. In that case get some belt dressing and see if taht helps.
I also heard that there are some 6# pulleys that are not true 6# pulleys. What brand pulley did you get? Hoe big is the lower pulley> Can you measure the diameter?
Old Oct 21, 2003 | 01:33 AM
BigFan's Avatar
Yeah something is wrong with you gauge, either the gauge itself or a leak in the fittings.
