ported eaton
Old Oct 17, 2003 | 09:30 PM
Danger's Avatar
Lightbulb ported eaton
Ran for the last time this year weds.ended with a
12.81 at 105 and a 12.83 at 105.Not my best but
can't complain.
Anyway to the important part my cousin just got
a ported eaton on his 03 cobra and made 40 hp at
the wheels.So i'm getting that and a dyno tune
computer flash in a couple weeks.
my current mods are a jlp chip,5# lower,ram-air.
made 367hp and 475trq on a bad air day so
as soon as i get the new #'s i will post the actual
sheets.The guy doing the work expects the truck
to pickup over 50hp at the wheels so we will see.
02 lightning #3767 black
best time 1.75 60ft. 12.59@106.03 on qtps.
2.06 60 ft. 12.97@106.58 on the f1's
Old Oct 17, 2003 | 10:18 PM
Stormyday's Avatar
50 hp. that is great.
Where are you having it done.
Chris
Old Oct 17, 2003 | 10:37 PM
l-menace's Avatar
sheets.The
these are terrible numbers for a 5# pulley.
Heck the stock pulley with the JDM chip should put that out no problem
my 3# is putting out ove 400rwhp.
get dyno tuned!
Old Oct 17, 2003 | 10:44 PM
svtdvm's Avatar
sheets.The
get dyno tuned!
He probably dynoed under load.
Old Oct 17, 2003 | 11:33 PM
Blk02's Avatar
Can somebody explain this ported eaton thing. I have heard of it before, but 50hp sounds like alot. Is this along the same lines as the ported upper intake?
Old Oct 18, 2003 | 01:33 AM
Danger's Avatar
The place is called stiegemeier dyno-tech in st. louis mo.
He tunes mostly mustangs and alot of testing on the 03
cobra now.I'm not sure the details on porting the eaton
but he said it should react better than the cobras because
the intake is more retrictive possibly?So i guess that they
will port the intake as well.
Old Oct 18, 2003 | 01:38 AM
promodlightning's Avatar
A ported Eaton. That sounds like a good mod, especially if it will pick you up 50 hp....
Old Oct 18, 2003 | 09:45 AM
MaxPower's Avatar
How much they asking to port the eaton?
I live in STL, and was going to go there to have the truck dyno'd...
Old Oct 18, 2003 | 12:16 PM
LightninMike's Avatar
yeah if you dont mind sharing the price with us that would be great, as i am now a little weird about putting a KB on the truck
this is what happened to one of the guys on svtperformance
http://www.svtperformance.com/forums...threadid=60966
dosent look good at all, and only after 1000 miles
Old Oct 18, 2003 | 02:11 PM
captainoblivious's Avatar
Porting the Eaton you can get more airflow.
50hp sounds like to high of number though. Maybe if the upper plenum gets spacer, is port matched the blower, gets a P&P and reshaped to help the air flow around the bend into the blower better. But even then 50hp sounds like to high of a number.
Old Oct 18, 2003 | 02:25 PM
l-menace's Avatar
porting the EATON???
the tolerances inside the eaton casing and the rotors are exact and messing with them will result in LESS EFFICENT supercharger.
Also, you can block the sound deadening holes on the bottom of the blower for a LITTLE extra boost.
Lastly, I'm assumming he is polishing the intake. with clay with diamond dust.
it will flow much better.
there was a post a few months ago about someone who reshaped the inside of the intake and increased the flow dramatically..
Also if you ahve a Phenolic spacer you can open the mouth of the intake to match it.
Also if you have a single plane throttle body, you can open the intake to match that, (almost 1/4" difference)
as for porting the eaton supercharger itself? I'm not too sure, messing with the tolerances is messing with efficency
Old Oct 18, 2003 | 02:29 PM
l-menace - when they say porting I don't think they mean the inside cast itself where the rotors spin. They may be refering to the inlet and the outlet of the blower where it still has the rough casting. You can open the input hole to match the plenum, and the outlet can be opened up some to let more air flow.
Well, when I ported mine thats what I worked on.
Old Oct 18, 2003 | 02:31 PM
TSDuke's Avatar
http://www.apten-us.com/
Old Oct 18, 2003 | 02:37 PM
l-menace's Avatar
they don't tell you on their site what they do to the supercharger.
Old Oct 18, 2003 | 06:29 PM
Ayrton's Avatar
http://www.modularfords.com/forums/s...&threadid=5808
