Any ill effects running 100oct all the time?
Well im sick of the truck pinging and trying to get it tuned. This CA gas sucks. Ive started adding about 5-10 gallons of 76 100oct per tank and it seems to take care of my pining. Is there any problems with running a 100/91 mix all the time? I have heard that the dye in race gas will clog up the filter quicker then regular, but thats no biggy, i can just change the filter every 3k miles when I do the oil. So again, any thing wrong with running 100/91 mix all the time????
J15BIG
The only ill effect I know of is on the wallet. It will be skinnier than with the 92 octane.
I have been mixing toluene and 104 with the crappy 90 octane I get at our local stations. I try to keep it around 95 and above. The L definately runs better.
Mark
I have been mixing toluene and 104 with the crappy 90 octane I get at our local stations. I try to keep it around 95 and above. The L definately runs better.Mark
You'll go through fuel filters quicker, as the face fuel is harder on the "paper" in it.
I wonder what the higher concentration does to the fuel lines and injectors since it leaves the plugs with a reddish hue??
Is your truck pinging under light loads or at WOT? If it is pinging at WOT only get an alcohol injection kit. It really works and will cost less in the long run.
I'll be in the bay area this afternoon. If you see a speeding rental car in the left lane please merge right.
Originally posted by Fast Gator
Its tough on the back tires too
Re: Any ill effects running 100oct all the time?
I was wondering the same thing also. There is a Union 76 by my house that has a pump with 100oct. I was thinking about puttiing in a couple gallons, i'll have to check if it's leaded or unleaded.
FRITZ, Stock Silver 2001 "L" BaBolt's s/s tips.
Its not leaded, unleaded 76 100 Cool Blue.
It costs 4.19/Gal and hasent raised in 6 months.
Since 91 is already around 2.20 adding about 10gal of 100 wont be too much more money.
It mostly pings at tip in so alcohol injection wouldnt be for me i dont think.
Newbie Q here - what does Load Up mean???
easterisland,
you should come to the NorCal SVTOA meet today. Serramonte ford in Colma...
easterisland,
loading up, refers to when an engine cylinders start filling with fuel at a rate that will saturate your plug and fill it with more fuel than it can efficiently burn...Ex rough idle,black smoke upon acceleration, popping sound ...
w/92 octane, chip set for 91
1. eco, no ping
2. street, ping at tip in
3. race, no ping with 100 octane
4.kill switch, no ping at all haha
easterisland,
easterisland,
