Grade 8 hardware question (for Lakewoods)
Old Oct 16, 2003 | 10:51 AM
fractaldragon's Avatar
Couple of questions regarding my Lakewood install this coming weekend:
Can I get upgraded hardware at a normal hardware store like Lowes, Ace, etc.
I assume I get the Grade 8 version of the EXACT hardware I get in Grade 5 with the kit. Are there any other additional items that I need? I searched earlier threads and people mentioned double-nutting. Do I need extra nuts, bolts, washers???
Thanks!
Old Oct 16, 2003 | 11:08 AM
frank22's Avatar
yes any hardware store has them in the screw section,depending how honest you are you can go home switch them and take the grade 5's back since it is a "bulk" sale nothing is on the reciept but how many you bought so your net cost could be "0"
I upgraded the nuts too
Old Oct 16, 2003 | 12:12 PM
Speedin Bob's Avatar
From: On the side of the Road attempting to explain 135 miles per hour
You might think about grabbing a piece of 3" strip steel to make additional shims, especially if you're planning on lowering the rear.
Take one of the grade 5 bolts with you and buy 4 grade 8's that are 1/2" longer for the front brackets so as to allow for shimming.
double nut all the fasteners.
pick up a couple of black snubbers at VatoZone also unless you like yellow accent pieces.
Bob
Old Oct 16, 2003 | 12:15 PM
I plan on doing my shackles Saturday too....which should I do first???? Lower it, then the bars or vice versa?
Old Oct 16, 2003 | 03:14 PM
shackles first, drive it a few miles, then Lakewoods.
