blowing antifreeze out radiator cap
Old Oct 17, 2003 | 03:18 AM
  #31
promodlightning's Avatar
Originally posted by rscoleman
I can't beleive that your built motor wasn't decked! Even if its a new block, I'd definately consider rebuilding this winter with a block thats machined properly. Also may want to check the tune, since detonation will cause blown headgaskets.
My Diablo tune was at 12.2 AF,
JDMs superchip is at 11 AF,
Old Oct 17, 2003 | 12:33 PM
  #32
BigFan's Avatar
Originally posted by owheelies
With the minor amount of material removed the cam timing wouldn't be changed very much at all. Less than a degree in all but the most extreme situations. The tensioners allow for chain stretch/wear adjustment well beyond what this would cause.
Eric
Eric
This is incorrect, timing will vary as much as a couple degrees. The amount depends on how much matierial is removed from the block and the head. While the tensioner will take up the slack, it will not correct the cam timing. Another disadvantage in this whole stiuation, it what the right bank does the left bank does opposite. When you deck the heads and block, your right bank will advance but left bank will retard. Currently their are a few companies working to remake the timing sprockets that SVO/FFRP made about 5 yrs ago, until then you run around with 1 bank retard 1 bank advance.
Promod
While a Lean A/F ratio can cause detonation, so can too much timing or even too hot a plug. Its possible to have detonation and still have a safe A/F ratio.
Old Oct 21, 2003 | 02:26 AM
  #33
My head was lifted prior to my custom dynotune with Willie Figeroa. When I retorqued my heads the problem seemed to of went away until last week. Now it blows antifreeze out at 10#s of boost and up. Thanks ...
Old Oct 21, 2003 | 03:05 AM
  #34
Bad as L's Avatar
BigFan
Steeda has a gear kit for about 80.00 that you can time the cams on a 2V motor. I haven't seen it and don't know how it works.
L&M racing engines 215-675-8485 or No Limit Race Cars 404-366-3037 also sell a cam gear kit but this is the real deal. It cost 525.00 but you can advance or retard the cams in 2* increments and it looks like you can go 8 or 10 degrees either way.
My block has been milled lightly and the heads are going on there second mill job so this mod is on the list.
Dale
Old Oct 21, 2003 | 11:07 AM
  #35
BigFan's Avatar
Thanks Dale, I knew that they were coming out but didnt know they were already on the market. I had a SVO/FFRP Set yrs ago but sold em, didnt need them at the time and didnt realize they would be discontinued for several yrs.
