5.4 Pistons Question
Old Oct 15, 2003 | 12:35 AM
seidler's Avatar
Ar ethe 5.4 and 4.6 pistons interchangable. I am looking for a set of 17cc dish pistons for my 2001 L and see mostly 4.6 pistons listed.
Old Oct 15, 2003 | 01:14 AM
SUX2BU's Avatar
no
Old Oct 15, 2003 | 01:17 AM
Ayrton's Avatar
The 5.4 and the 4.6 use the same piston and yes they are interchangeable. What makes a 5.4 is the taller deck height and longer stroke.
Old Oct 15, 2003 | 03:23 AM
Bad as L's Avatar
The 4.6 and 5.4 pistons are interchangeable. I got JE 4.6L 17cc dish pistons in my motor.
Dale
Old Oct 15, 2003 | 10:22 AM
seidler's Avatar
Thanks I am getting the JE's ordered today.
Old Oct 15, 2003 | 09:38 PM
Jeff's Bolt's Avatar
No they are deferent in the compression hight,but same bore size.
Jeff
Old Oct 15, 2003 | 10:22 PM
seidler's Avatar
I have been told by Pro Power today that the 4.6 17cc dish piston is the one to use in the 5.4 Lightning. It does have a different compression height but that is what Ford wanted in the L with the blower. My machine shop ordered the JE's today.
Old Oct 15, 2003 | 10:29 PM
LightningTuner's Avatar
The pistons are the same piece for the 4.6(2v) and 5.4. Ford gets the different compression from the 5.4s piston being .117 in the hole.
Old Oct 16, 2003 | 12:23 AM
Ayrton's Avatar
Sal,
Using a 17cc piston and assuming the stock head gasket what compression ratio will you have in the Lightning?
Old Oct 16, 2003 | 01:04 AM
SVT F15O's Avatar
Originally posted by SUX2BU
no
Opps!
Old Oct 16, 2003 | 08:22 AM
seidler's Avatar
The same as stock.
Old Oct 16, 2003 | 08:36 AM
JohnnyLightning's Avatar
yes they are , get the CP's my friend......JL
