Question about Traction bars. Help please...
Old Oct 14, 2003 | 10:26 PM
NTIMD8's Avatar
Originally posted by fractaldragon
Where you getting your Lakewoods from?
I live in Canada. There is a local speed shop that has them for $150 Canadian so that about $109 US
Old Oct 15, 2003 | 12:33 AM
LTNBOLT's Avatar
Lightbulb
NTIMD8,
If you know the right people get them to built a set of bars. My cousin built me a set of slapper bars. We pulled the right tire off and measured for the long bar length first. We kept measuring and adding a piece until we had them finished. I bought the snubbers first so we could get the distance right for them. I wrote the deminsions down and put them in this drawing.
P.S. On the second set we cut a slot from the front of the bar back to the hole drilled for the snubber. This allows you to loosen the nut on the bottom of the snubber and slide it out the front of the bar to haul a load.
Old Oct 15, 2003 | 12:36 AM
LTNBOLT's Avatar
Old Oct 15, 2003 | 10:45 AM
SVT_KY's Avatar
Well, I have the TrucTracks, and they have perfromed
flawlessly, including saving the entire bottom of the truck
from destruction in my wreck.
The benefit of the lafewoods and the TT's is that they are NOT always
working. Believe me there is no comparision in the quality
of Jay's TT's ... Sal uses them on the FASTEST GEN II so
that means they must work, huh?
And with Jay, you're deling with a REAL person ... he offered
to replace the bolts and hangers when I had my wreck. Quite
an offer that I don't think you would get from the larger vendors.
Cliff
Old Oct 15, 2003 | 10:56 AM
fractaldragon's Avatar
I just ordered a set of Lakewood's this morning. They will serve my purpose for now and I just can't justify spending $250+ more on something doing the same thing. Once I get more power, I may change, but these are better than nothing and will eliminate most of the axle wrap. That combined with the -2 pinion angle I will be getting from my drop shackles, I should be fine for a while.
And I agree...their strong point is that they are not always working and you can get a normal ride quality...
Old Oct 16, 2003 | 10:17 AM
NTIMD8's Avatar
LTNBOLT, Thanks for the diagrams! Thats great work. I decided to go ahead and order the Lakewoods. At only $150 Canadian it was no big deal. If I find I dont like them then I will sell them to a regular F-150 owner and either build my own slappers, go with the TT slappers or to the JLP rancho style traction bars. I am sure the Lakewoods are gonna be just fine, esp after I upgrade to grade 8 hardware.
Thanks for all the info guys!! As usual you guys
to f150online!!!
Old Oct 16, 2003 | 10:29 AM
l-menace's Avatar
check classifieds here and f150online.com
lakewoods are alays for sale in here
Old Oct 16, 2003 | 10:45 AM
NTIMD8's Avatar
Thanks but I already orders them. My cost was $130 Canadian plus tax. So thats like $98 US. I want to get them on th etrack as soon as it comes back from getting a new drive shaft from breaking it with slicks and no traction bars. I wish I knew about needing traction bars to prevent axle wrap before I blew my U-joint and drive shaft
Old Oct 16, 2003 | 10:48 AM
NTIMD8's Avatar
Also you say here and f150online? Umm this is f150online
Old Oct 16, 2003 | 10:53 AM
litnfast's Avatar
Jegs site lists part # 21715 as 86-99 F150. Are these the correct ones for an 01-04 Lightning?
Old Oct 16, 2003 | 10:55 AM
Yup. That's the part # I ordered from Summit yesterday.
Old Oct 16, 2003 | 10:58 AM
litnfast's Avatar
