Phenolic spacer.
Old Oct 12, 2003 | 01:44 PM
Odin's Wrath's Avatar
Phenolic spacer.
I just broke mine out with the intension of putting it on finally. Did any of you guys think to gasket match the spacer with a dremel before installing it? Mine was too small by nearly 1/4 inch at one end. It is now perfect. It's easy to do really, just not something everyone thinks of.
Old Oct 12, 2003 | 01:47 PM
whip's Avatar
Thats a good idea, but mine was dead nutz on!
Old Oct 12, 2003 | 01:48 PM
whip's Avatar
Re: Phenolic spacer.
I don't think a 1/4 inch will matter....but they do make pumps and such if you have a complex!!!!!
Old Oct 12, 2003 | 02:15 PM
MORTIS's Avatar
Odin's wrath, not trying to start a flame war or tuner bashing but, who's phenolic spacer did you buy? I was wondering if I needed to do that also, since I just ordered one, and am waiting for it in the mail.
Old Oct 12, 2003 | 02:18 PM
Re: Re: Phenolic spacer.
Very funny. Haha. I've actually been thinking of a reduction. My girlfriend is starting to look like this---> all the time.
Seriously though, 1/4 of an inch all around one side and corner is quite a bit of material. Every little bit helps. Right?
Old Oct 12, 2003 | 02:20 PM
It's not a big deal really. It only took a few minutes to match it up. I'd check it out no matter where you get it from. Couldn't hurt.
Old Oct 12, 2003 | 02:27 PM
03LightninRocks's Avatar
I am a bit confused here. The gaskets that came with my spacer were Ford part number gaskets and where the exact gaskets that Ford uses on my existing plenum. How could they be off unless you got a bad set from Ford.
I bought my spacer from JDM at the FFW Ennis event as a way of showing appreciation for the tent he provided for us.
It took me all of 30 minutes to install and the kit fit perfect. Guess I got lucky????...LOL. Naw...I think someone is being ****...J/K.
Where your gaskets not the Ford gaskets?
Rocks
Old Oct 12, 2003 | 02:29 PM
Rocks
Not the gaskets, the spacer was off. I matched it to the gaskets. Sorry to be inspecific.
Old Oct 12, 2003 | 02:31 PM
whip's Avatar
I think he meant the spacer was smaller than the gaskets, so he enlarged it to the exact same size as the gasket, which could make a difference in the flow.
edit....dohhh he beat me to it.
Old Oct 12, 2003 | 02:39 PM
Oh Shiot.....I see what your saying now!!!! I wish to heck I had of looked at this before I installed it.
So with the spacer protruding inside the plenum...the air is not flowing as smoothly. Great idea...it may be a minimal issue but at a certain level of mods, every little bit helps.
I'll probably be pulling mine to check this down the road. Thanks for the tip.
Rocks
Old Oct 12, 2003 | 03:08 PM
whip's Avatar
Hey 03....FWIW mine is JDM and it was perfect....I sugest waiting until you really have nothing else to do before checking this!
Old Oct 12, 2003 | 03:18 PM
That's good news. I guess the ones that are made by the "knock off" "me too" guys are the ones needing extra work.
I plan to go with the works 140 in the next couple months anyway...so I believe I'll just take your advise.
Thanks,
Rocks
Old Oct 12, 2003 | 03:20 PM
Yeah. If mine was already on the truck I probably wouldn't pull it off just to check. I would put it on a list of things to do providing I pulled the plenum for something else, or just got bored. Mine looked good until I put the bolts through it. That's when things were off.
Old Oct 12, 2003 | 03:25 PM
Rocks
Mine's not one of the "me too" pieces. It doesn't matter where a part comes from, they're not all going to be perfect. It pays to check. There's no malice involved in this post. Just trying to be helpful.
Roger
Old Oct 12, 2003 | 03:29 PM
Roger
I was just making an attempt at humor. I was bored and thought I'd poke a stick at the tuner cage...LOL.
Rocks
