I need opinions on possible causes...
Old Oct 10, 2003 | 01:00 PM
pn7263's Avatar
Question I need opinions on possible causes...
I have a bone stock 2002 L with 17K miles. When I get into it at 3/4 throttle the engine begins to stutter. If I push it to WOT then it will usually pass thru it and pick back up again. If I back off and then go back to 3/4 then it usually doesnt do it. This is very consistent. Hot engine or cold, it doesnt matter. Warm or cold outside, no difference. I am just looking for a little information to take to the dealer so I can be informed on what they should be looking for. Any help is appreciated.
Thanks,
Old Oct 10, 2003 | 01:32 PM
firemx220's Avatar
When was the last time you changed your fuel filter?
Old Oct 10, 2003 | 01:34 PM
DEIMATT's Avatar
7th fetzer valve??
Old Oct 10, 2003 | 01:45 PM
lightning00n93cobra's Avatar
Either a plug, fuel filter, coil pack or oil on the mass air meter
Old Oct 10, 2003 | 04:05 PM
PWR_WHLS's Avatar
Is the vibration/shutter felt in the steering wheel or the whole vehicle or both?
Old Oct 10, 2003 | 04:08 PM
soap's Avatar
Bingo.......
--Joe
Old Oct 10, 2003 | 05:32 PM
pn7263's Avatar
I have never replaced the fuel filter and the stuttering feels like when a carburator acclerator pump quits working. Other than this the truck starts and runs perfect.
Old Oct 10, 2003 | 05:38 PM
illegalspeeds's Avatar
I have 17,000 miles on my 2002 Lightning, how often should we be changing filters?
Matt
Old Oct 10, 2003 | 05:52 PM
litnfast's Avatar
I have changed my fuel filter twice. My 01 has 17k. I look at it as insurance against going lean. Some do it every oil change.
Old Oct 10, 2003 | 08:30 PM
engelmb's Avatar
I am having the same problem with my 2000 L. I am at about 37000 and I am not sure if the fuel filter has ever been changed. Does anyone have instructions on how to change this thing? I just got my L and I am not too familiar with it yet. Thanks for your help guys!
Old Oct 10, 2003 | 08:50 PM
Fear Itself's Avatar
Here you go!
http://www.svtlightnings.com/svt/how...fuelfilter.htm
Old Oct 12, 2003 | 08:52 PM
pn7263's Avatar
Exclamation Filter Changed, Still have problem
Ok, I changed the fuel filter and the problem is still there. No better, no worse. More suggestions? By the way I also changed the fuel filter on my wifes 01 Exp. and it made a huge difference!
Old Oct 13, 2003 | 01:56 PM
PWR_WHLS's Avatar
Re: Filter Changed, Still have problem
Plugs! - check you plugs. I'd bet you have a loose plug. I have a plug that was backed halfway out, third back on the passengers side. I felt no difference in the throttle until I was 90%+ on the long pedal! ?!
Good Luck,
john
