How much boost can the rods take
Old Oct 6, 2003 | 11:32 PM
johnathanh's Avatar
Question How much boost can the rods take
I was wondering how much can a stock motor take??
because i am going to buy a 6# and some ngk tr6
i have only a knn
Do you think it's safe??
thanks
Old Oct 6, 2003 | 11:34 PM
Probleminfected's Avatar
you need a chip for that much boost
other then that you'll be fine, unless you get a jitty tune
Old Oct 6, 2003 | 11:41 PM
l-menace's Avatar
don't drive it without a chip.
you will be LEAN and well EXTREMELY LEAN and will burn a hole in the piston.
GET a chip, get it dynotuned!
Old Oct 6, 2003 | 11:51 PM
johnathanh's Avatar
and a 4# would it be safe without a chip
Old Oct 6, 2003 | 11:56 PM
therealgeronimo's Avatar
That is a can of worms, some people say it is safe others say it isn't. I personally would have a chip.
Old Oct 6, 2003 | 11:58 PM
i ran for an extremely long time with a 4lber and no chip, i checked my plugs, no fouling (it20's)
Old Oct 7, 2003 | 09:38 AM
Lightningquick's Avatar
Personally i think 4lbs is fine without a chip.I ran it for a while without a chip.Although it ran better and the boost was a little noticable,It was far from what a chip alone could do.I got a chip because I wanted to feel the full effect of the pully and go faster.My truck ran 12.60 all day long with a chip/pully/ THATS IT!! I didnt even add an air intake until after I went to the track. I think from past experience you will knock off about 2-4 tenths (NO MORE) with just a p4# pully. You really need a chip to make a difference.You could drop off a whole second like I did!! with just a chip.pully!Yes I was on slicks.My truck ran 13.6 STOCK!!
Ill put it this way.
The chip alone makes 100% difference from stock
the pully alone makes about 40% diffference from stock
You do both chip/pully and you gain an additional %60 making your truck run 200% better??????? Get it ??????
Old Oct 7, 2003 | 10:00 AM
Cali L's Avatar
It's in the tune Mines daily driven 80 miles, plenty of kickdowns, etc. No problems(Knocking on my desk now).
BD
Old Oct 7, 2003 | 10:41 AM
KB ZILLA's Avatar
My A/F's were fine with the 4lb , cold air and no chip, I even ran a 6lb -no chip for awhile.....but my friends 01 with the same 4lb and cold air with no chip was lean...on the same dyno.
Each truck is different...If you go without a chip, get your A/F's checked on a good dyno!
Old Oct 7, 2003 | 11:41 AM
ICULOKN's Avatar
17-18lbs of boost
Stock Motor
Stock Tranny
26,000 miles when I sold it, (STILL ON ALL STOCK PARTS)
1223 track passes plus weekend nights on the streets
11.7x's best ET's
Old Oct 7, 2003 | 02:09 PM
johnathanh's Avatar
thanks guys
Old Oct 7, 2003 | 02:56 PM
ShaneMcKenna203's Avatar
Originally posted by ICULOKN
17-18lbs of boost
Stock Motor
Stock Tranny
11.7x's best ET's
I love reading that 1223 track passes your the man!
Shane
Old Oct 7, 2003 | 07:33 PM
SCC2000L's Avatar
I think the question may not be so much: how much boost can the rods take... but how much heat at detonation can they take. There are guys now days with KB blowers running 15lbs of boost that are making some serious power and the engines seem to be holding up from what I am gathering. So who knows!
Old Oct 7, 2003 | 08:22 PM
Red BOLT99's Avatar
15 lbs onthe street
and 22 lbs @ the track
11.7 @ 17lbs
Stock Block
Stock Tranny
3:55 gears
Old Oct 7, 2003 | 08:52 PM
s.cal L 2's Avatar
8# lower no problems yet, it pulls hard but after like 5-10 minutes of driving it it loses power. I dont daily drive it just for track use so I dont worry
