What Optima
Old Oct 5, 2003 | 11:47 PM
Casey02L's Avatar
What Optima
I want to get a yellow top optima; what size do I need for the L? I looked on there site, but it is kindof hard to look it up.
Old Oct 6, 2003 | 09:22 AM
LIGHTNINROD's Avatar
bump
Old Oct 6, 2003 | 10:51 AM
brain bypass's Avatar
this is what i came up with. i can see what model my yellow top is that i have at home that will be going into my truck, i will be using a new battery hold down though.
http://www.optimabatteries.com/using...ar=40&brand=71
Old Oct 6, 2003 | 09:23 PM
Casey02L's Avatar
Well; I did that. From what I read it says a group 75, but that is only in a red top. I want a yellow top, so what group is that
Old Oct 6, 2003 | 09:54 PM
LatemodelRacer2's Avatar
i thought there was only one size?
Old Oct 7, 2003 | 08:57 AM
KB ZILLA's Avatar
I went to Autozone and bought my Optima last week. They looked up the part number for both the red and the yellow ones.
I got the red to match my truck
Old Oct 7, 2003 | 10:21 AM
when i bought mine, i just got the d34/78 model, there is pretty much two 12 volt models, the d34 and the d34/78. i think the only difference is the d34 has the posts on top, and the d34/78 has both top and side posts. i got mine form interstate batteries, you will probably just need to figure out a way to mount it in the battery tray. do a search, i have seen a few different aluminum battery trays from members here to hold optimas. make sure to get a yellow top if you are running any amplifiers for a stereo, cause it will void the warranty if you use a red top
Old Oct 7, 2003 | 10:38 AM
KB ZILLA's Avatar
My red top came with adapters to bolt down directly into the factory tray.
I plan on gettng a billet hold down later on when I start adding goodies to brighten up the engine bay!
