question about second battery
Old Oct 1, 2003 | 05:07 PM
brain bypass's Avatar
i wanted to add a second battery for my stereo ( i already have a yellow top sitting in my garage) and i was thinking about getting a battery box that mounts on the frame rail. i know that if you relocate your battery, nhra regulations require you mount a shutoff swicth clearly marked on the rear of the vehicle.
my question is this, if i mount the second battery on the framerail and it is hooked up with a battery isolator, do i need a shut-off switch to pass tech?
thanks
-glenn
Old Oct 1, 2003 | 05:29 PM
svtdvm's Avatar
A second battery is not necessary unless you are planning on playing your system full volume with the truck not running. Put your money toward stronger alternator instead.
Old Oct 1, 2003 | 05:44 PM
i fully understand car audio systems. i already have the yellow top. i will get an alternator eventually, i already have it picked out. my question was concerning a shutoff switch.
but thanks for trying to help.
