Raising the Lightning
Old Oct 1, 2003 | 04:36 PM
slvrz06's Avatar
Has anyone raised the front of the Lightning to even height with the rear? Would there be ride problems? Or any other problems?
JS
Old Oct 1, 2003 | 04:38 PM
MaxPower's Avatar
There'd be UGLY problems...
Too high to begin with, then add more height to the front? Much easier to drop the back 2"...
Old Oct 1, 2003 | 04:41 PM
RipNRun's Avatar
That's probably the wrong question on this board. The last guy that posted something like that is still recovering from the thrashing. Good luck.
FWIW, you'll lose some handling. Lowering helps the handling by creating a lower center of gravity.
--Rip
Old Oct 1, 2003 | 04:43 PM
l-menace's Avatar
100 times easier to buy lowering chackles (find them used for $40) and lower the rear 2".
takes about 30 minutes to do and the only thing you need to adjust if you are ****, is the aim of the headlights.
Old Oct 1, 2003 | 04:58 PM
swiseuf's Avatar
I was wondering about this-do shackles worsen the handling as far as wheel hop/axle flex is concerned?
Old Oct 1, 2003 | 05:01 PM
l-menace's Avatar
it helped mine.
lowering the rear, puts the pinion angle at a negative degree.
when you floor it, the axle will twist (just like stock) but hte angle will not be as severe.
http://www.paulshp.com/lightning.htm
go about 1/2 way down and read about the shackels
