What is this TICKING sound?
Old Sep 30, 2003 | 07:51 AM
fractaldragon's Avatar
Brand new truck, 300 miles. I hear a tick when I am outside the truck while it is running (ie in park at idle). Sort of like a diesel sounding tick. Seems more prominent on passenger's side of vehicle.
Could it be an injector I am hearing? Or something worse? It is very subtle... I have heard a loose heat shield before and am pretty sure it isn't a loose heatshield.
Ideas?
Thanks!
Old Sep 30, 2003 | 07:56 AM
Lightning Boy's Avatar
Probably the injectors. If it gets worse with more miles, you've got other problems.
Old Sep 30, 2003 | 10:38 AM
Should I take it in already???
Old Sep 30, 2003 | 11:23 AM
BlkLtng02's Avatar
Check all the plugs to make sure they are not loose. I know it is an 03 with the new heads, but it's better to be safe than sorry.
Old Sep 30, 2003 | 02:27 PM
I am dropping it off tomorrow to have them checked. Anyone had loose plug problems on an 03??? I know they 01/02 models had some issues...
Old Sep 30, 2003 | 07:37 PM
SpeedJunkie's Avatar
If its that subtle, my best guess is injectors.
Old Sep 30, 2003 | 08:23 PM
What can be done about it?
Old Jan 24, 2004 | 11:14 PM
Sharpshooter's Avatar
I know this is an old one, but was your problem ever solved? Did you find out what the ticking sound was.
Old Jan 24, 2004 | 11:26 PM
AmoJohnny's Avatar
low oil?
Old Jan 25, 2004 | 12:15 AM
soap's Avatar
It's the injectors...........nothing to worry about.
--Joe
Old Jan 25, 2004 | 12:25 AM
LatemodelRacer2's Avatar
mine is making a noise that has never done before. IT started last week. The best way to describe how it sounds is when you unhook the vac line of the bypass on the s/c excpet it is coming from the underside of my truck. It only does it at idle. The other day i checked the plugs and one of the plugs had oil on the threads not shure if this is my problem or partof it.
Old Jan 25, 2004 | 12:35 AM
Just changed my plugs also, and reinstalled my ported Eaton. I'm not sure if the noise was there before or not, I really didn't pay much attention before.
It sounds like it is coming from the passenger side.
Old Jan 25, 2004 | 03:51 AM
Holy resurrected post Batman!
Mine still ticks and it is on the passenger side...INJECTORS
