Why is the truck not starting up in the cold?
Old Sep 29, 2003 | 09:45 PM
cobra97snake's Avatar
hey guys lately the lightning takes a few trys to start up in the colder weather, whats the deal???
i pulled my chip and it still does it....
last year it wouldn't start at all, and i found that my wires to the starter were messed up, and i fixed that, so what could be the problem now???
Old Sep 29, 2003 | 10:24 PM
svt_sc_f150's Avatar
Well what do you mean doesn't start? Crank no start, no crank no start. Big diff.
Old Sep 29, 2003 | 10:58 PM
svt00L's Avatar
how thick of an oil do you use?
Old Sep 29, 2003 | 11:35 PM
REDY2KL's Avatar
replace your starter solanoid that might be it and it only costs about $9.00 bucks at your local auto parts store.
Old Sep 29, 2003 | 11:41 PM
cranks, cranks, and cranks, and just doesn't start.
i do it a few times, taking 10-20 sec breaks in between, and usually by the 3rd to 4th time it starts right up.
but heres the kicker, sometimes after i start it, it pops up RPM's like normal to 12-1500ish, and then drop dramactically below 500rpm and almost stalls out, and then recovers....??
oh, and i use 5w30
UPDATE: Pulled all plugs, they are all in good shape except for the tips are all white/goldey in color.
Old Sep 30, 2003 | 02:40 PM
LIGHTNINROD's Avatar
Dirty/worn, stuck closed IAC valve.................??? Tap it with a 'soft' hammer and if that 'fixes' it, then remove it and soak/flush it with brake/carb cleaner. If it's worn, replacement may be necessary???
Dan
Old Sep 30, 2003 | 04:25 PM
sixpipes's Avatar
Bad IAC valve or a leak in the vacuum lines going to it. I recently had similar problems after knocking one of the vacuum lines loose while changing plugs on the passenger side. $.02
