intercooler fans & heat exchanger
Old Sep 24, 2003 | 09:48 AM
ShaneMcKenna203's Avatar
Do they only help you when you are at idle?
When you are moving aren't you getting enough air through the lower grill forced into the stock heat exchanger? (Below where the license plate would be) Or am I way off at what intercooler fans do. Can I get more info on Spal intercooler fans and a heat exchanger even? Also is the way to power the fans a switch or how to you power them? Also what is an intercooler pump and switch? I am interested in getting my truck to run cooler (like it is now in the 60 degree whether) in the summer.
Thanks, Shane
Old Sep 24, 2003 | 10:50 AM
soap's Avatar
Some more info here.
--Joe
Old Sep 24, 2003 | 11:38 AM
thank you very much. will they help me without upgrading the heat exchanger? or do them both at the same time? thanks, Shane
Old Sep 24, 2003 | 11:56 AM
soap's Avatar
They helped me a lot. I had my IC pump, IC fans and main fan wired to switches. I could get a 95% cooldown in about 10 minutes.
Also unless you have an electric water pump I would start your truck for like 15 seconds (in the pits) just to get the heat soaked coolant out of the block and back into the radiator to cool it down.
--Joe
Old Sep 24, 2003 | 12:06 PM
I am thinking about getting electric fans and a water pump. Along with the intercooler fans and a heat exchanger in the future. What is the intercooler pump?
Thanks, Shane
Old Sep 24, 2003 | 12:54 PM
soap's Avatar
Thanks, Shane
The pump that circulates the coolant thru the IC system.
It's that black pump that has a white Bosch sticker on it in the pic you posted.
--Joe
Old Sep 24, 2003 | 02:14 PM
do we have a pump stock? just the on/off switch we install? or how does that work? thanks for all the help. Shane
Old Sep 24, 2003 | 02:18 PM
soap's Avatar
Yes every truck has a pump stock. I just wired a switch to turn it on/off whenever I wanted.
--Joe
Old Sep 24, 2003 | 02:55 PM
why would you wanna turn the intercooler off the pump?
Old Sep 24, 2003 | 06:51 PM
soap's Avatar
Not sure what your asking.
In stock form the pump comes on thermostatically. However with a switch you can ALWAYS run it.
Also with a switch you can run it in the pits.
--Joe
Old Sep 24, 2003 | 06:57 PM
Thanks. What's better two 6.5 inch'ers or one 8 inch spal fan? The 8 inch one you can get for like $60 itself I think. The 6.5's are $55 each I think... Any advice? Thanks, Shane
Old Sep 24, 2003 | 08:42 PM
Fast Gator's Avatar
Re: intercooler fans & heat exchanger
Thanks, Shane
Hey, that picture looks familar
Old Sep 25, 2003 | 08:07 AM
Re: Re: intercooler fans & heat exchanger
thanks for the pic gator
Old Sep 25, 2003 | 10:05 AM
soap's Avatar
Well the 8" fan will be a major ***** to fit on the stock exchanger. I used 2-6.5" fans. It covers more of the radiator anyway.
--Joe
