A little smoke ok?
The other night I was cruising on the interstate, and punched it a little to avoid being cut off by slower moving traffic. As I was accelerating, I noticed a puff of smoke coming out of the pipes because another vehicles headlights behind me illuminated it. I have never noticed it during the daytime, so its not thick smoke or anything. My truck has 2000 miles on it, no mods and runs great. Is a little smoke OK? Is this because of the forged pistons? What are some causes of this? Your input is appreciated.
You have absolutely nothing to worry about. These trucks run pig rich. That is what you saw. Anytime you punch it at night with headlights behind you you will see what looks like the exhaust trail of a F-16 behind you. It's just the signature of raw power
Mine does the same thing, get the tips all cleaned, then get the urge to lay into the pedal and look back and see smoke in the headlights of the cars behind...Then i get home and see the insides of my tips are black again.....
This is absolutely NORMAL. You have nothing to worry about. I ASSURE you there is NOTHING wrong with your rings. As is stated above, that is just the unburned fuel exiting your tailpipes. It's all good
Later,
Rob
Later,
Rob
