unusual question about boost bypass
Old Sep 21, 2003 | 12:11 PM
Bryce_Thomason's Avatar
unusual question about boost bypass please read!
i have heard that it is ok to just unplug the boost bypass sensor, but i really dont want to do that. can i tap into the wire and put a switch in the cab so i can turn it off and on. has anyone tried this, will i have problems if i switch it while running? just want to keep it stock for everyday driving.
thanks in advance
Old Sep 21, 2003 | 12:39 PM
LatemodelRacer2's Avatar
ive never thought about running a switch in the cab. This could work
Old Sep 21, 2003 | 01:21 PM
Grimace's Avatar
All one would have to do is find the power wire to the solenoid, cut it and splice in your switch. But why would you wanna switch it? If you are boosting up over the stock amount, it will bypass anytime you restore power to the solenoid won't it? At wot obviously, not at idle.
Old Sep 21, 2003 | 08:41 PM
anyone have any thoughts on this?
Old Sep 21, 2003 | 09:24 PM
georgia-SVT's Avatar
Now are you saying that you will blead off boost if you add a bigger crank pulley because I have a 3#ER and my gauge shows the added boost.
jeff
Old Sep 21, 2003 | 09:36 PM
Grimace's Avatar
jeff
Well, not exactly. I think I meant to say that it will bypass boost if it exeeds the preset overboost pressure.
Old Sep 21, 2003 | 09:56 PM
Whats the preset overboost pressure.Or are you just talking about the boost levels in first gear.I noticed that mine is limited until I get to 2nd which is a safty feture for the 4r100 tranny.
jeff
Old Sep 21, 2003 | 09:59 PM
well would switching it off and on while driving prove to be a problem?
Old Sep 21, 2003 | 10:54 PM
Grimace's Avatar
I have no idea what the preset pressure is. I am sure that someone will post it.
Old Sep 21, 2003 | 11:12 PM
cpeapea's Avatar
ive never unplugged or disabled mine, ive never had any dump problems, ive never dumped boost even once and im running a 6lber and have so for about 10k
