Advice on LIFTING truck in the front...
Just put my 24's on the Harley last night, and rubbing in front a little. (24x10 on 305/35/24)
Wondering if anyone of you guys here, know of the best way to RAISE the front up an inch or so?
Thanks fellas.
Thanks fellas.
The only thing I can think of is to install a set of 2" lift coils and alignment bolts.
I don't know if there is a urethane spacer available to lift it. If there is, then try that along with the cam bolts.
Good luck,
Mike
Good luck,
Mike
Good luck,
Mike
Good luck,
Mike
im also wondering if stock springs from a non-harley supercrew will raise it just enough..
I just checked out WWW.JCWHITNEY.COM
They are called Daystar leveling kits.
The standard SuperCrew springs may work. I never thought about that. Maybe someone in your area has an extra set sitting in a corner to try or sell.
Mike
Mike
Bill
Originally posted by Unoid
christ give us some pictures of your hd with 24"s haha
Mike
Mike
Here's the post to pictures of the 24's.
https://www.f150online.com/forums/sh...96#post1078696
WISENHIEMER,
I've done that once. The only way the springs will work upside down is to put it on it's roof. It's not a good thing to play with sprung and unsprung weight this way. The vehicle doesn't run very well in this condition.
Nice name by the way.
Mike
Mike
Re: Advice on LIFTING truck in the front...
You making the JLO meet on the 28th????
Re: Re: Advice on LIFTING truck in the front...
Originally posted by Fast Gator
Two words........FLOOR JACK
