Water injection questions
Old Sep 20, 2003 | 09:36 AM
easterisland's Avatar
I am going to get a water injection kit soon. I have a couple questions.
1. Do I have to decrease the spark plug gap at all?
2. Where have you guys mounted the bottle? I was thinking in front of the windshield washer reservoir...
3. Where is the best place to install the sprayer? Before the throttle body, after the throttle body, after the supercharger and before the intercooler?
Old Sep 20, 2003 | 10:26 AM
99svtlightning's Avatar
1. Do I have to decrease the spark plug gap at all? I would run the gap the same, since you have lots of boost.
I removed my washer resorivior to make more room, that seems like a suitable place.
3. Where is the best place to install the sprayer? Before the throttle body, after the throttle body, after the supercharger and before the intercooler? I would install the sprayer in the rubber boot or pipe, if you have one. That's the easiest place and where I ran mine. You could use a nitrous plate to make a cleaner install.
Basically, the injection kit will let you run more timing safely. You can run regular pump gas on the street with a lot of boost and more timing also. I doubt you'll get a power increase if you leave everything the same and just run the kit. We tested a Snow kit on my buddies truck and that was our results. Let us know if you find out something different.
Old Sep 20, 2003 | 10:30 AM
How much more timing?
I am going to get a SMC kit. Their shop is 30 minutes from my work.
Since I use nitrous should the sparyer for the alcohol be close to that or before or after. I have the PSP plate for the nitrous.
Old Sep 20, 2003 | 11:37 AM
camcojb's Avatar
Just make sure that if the nozzle is placed in between the blower and throttle body (vacuum area) that the kit has a separate shut-off valve to prevent siphoning. Some kits do not have that and the vacuum will pull the water through the pump any time the engine is running.
I had excellent results with water injection on a ProCharged 540. The power will come from being able to run more boost and/or timing. If you don't change either of the above there won't be a measurable difference in power from the water injection. You get some air temp reduction if it's added upstream some, but the main place it does it's work is in the combustion chamber by absorbing heat. I always used plain distilled water as it is a better heat absorber than alcohol; however, if you're a little short on injector size, the alcohol will give some added fueling and octane.
Jody
Old Sep 20, 2003 | 11:47 AM
It'll have a switch to prevent siphoning.
Old Sep 20, 2003 | 03:54 PM
Suavy's Avatar
http://www.syclone.freeserve.co.uk/waterinjection.htm
I'm passing this info that was given to me hope it helps. I'm gonna get this ASAP
Suavy
Old Sep 21, 2003 | 03:32 AM
Well, it is installed. It is the best mod I have done to my truck to date. 20 degree timing and 20/21 psi boost in 55 degree weather without any detonation that I could hear. All on 93 octane pump gas. It is cool to burn the tires at 60 mph!
I got the SMC kit and couldn't be happier. The man ho owns the company lives 30 minutes from me.
SMC
custom install
Old Sep 21, 2003 | 05:42 AM
Bad as L's Avatar
Hey easter
What mixture did you settle on or are you still experimenting with that. ( alcohol/water) What kind of alcohol are you running? Did you get the new SMC kit that is designed for supercharging?
Thanks Dale
Old Sep 21, 2003 | 09:31 AM
I am using 100% alcohol and a lubricant. Steve is going to make a Lightning specific kit, but it isn't 100% ready yet.
The controller is the cool part. You can adjust how much the pump pums and the amount of boost you want before there is any spray. Also there is a solenoid to prevent siphoning.
It was just installed at around 11 pm last night, but it is awesome.
Old Sep 21, 2003 | 11:35 AM
CHIKIN1's Avatar
Easter: Update the time in your sig
Old Sep 21, 2003 | 02:35 PM
My best is a 7.243 at 96 something, but I think the 7.303 at 81 sounds more impressive.
Old Sep 21, 2003 | 02:44 PM
LatemodelRacer2's Avatar
we need more 1/4 miles in the south. i think the closet 1/4 tome is like 2 hours. But there are 4 1/8miles within an hour.
Old Sep 21, 2003 | 03:24 PM
promodlightning's Avatar
20 degrees of timing and 21#s boost.... I only have 14 dgrees. My race program, which isnt done yet, will go to 22-25 degrees. Am shooting for 750hp on pump gas with a 90% mix of alcohol. And 900 with race fuel and 26#s boost and a 75 shot nos dry kit....
Old Sep 21, 2003 | 07:02 PM
RDY2RAC's Avatar
i know you are more of a street racer but if you plan on running NMRA water or alk. injection is not allowed. not sure about ffw just to give some of the other guys a heads up. they do check everything under the hood now.
Old Sep 21, 2003 | 08:07 PM
400HPHD's Avatar
Easter, If oyu dont mind, where did you mount the nozzle and what size nozzle jet are you running??? Any pictures of it installed??
