Need help fast, please! Bad gas?
Old Sep 18, 2003 | 08:34 AM
jakemarietta's Avatar
Sta-bil is the best treatment
I've found for water in gas. Use it in my lawnmower,blower,trimmer, and boat. If I've forgotten to put in the fall, adding in spring and waiting half hour to work usually starts tool right up when it wouldn't start before. Good Luck
Old Sep 18, 2003 | 09:37 AM
lurker's Avatar
If it seems to idle fine but doesn't want to take any throttle, it's probably a hose that's popped off the pump.
Old Sep 18, 2003 | 11:53 AM
rqbrown's Avatar
Well, it's looking like I'll probably get an Autotap or another Scan tool to pin-point the issue this evening.
We're looking at the EGR/vacuum line angle, as well, in addition to fuel delivery issues and maybe a bad-coil pack.
I'm looking to get this issue resolved before FFW/Ennis and LFest '03.
Thanks,
Ronald
Old Sep 18, 2003 | 02:01 PM
MaxTorque02's Avatar
Originally posted by LTNBOLT
Go get a bottle of Isopropyl Alcohol and pour it in the tank. This is the part of Gas Treatment that helps to remove water. Gas and water don't mix but the alcohol mixes with gas or water. Gas treatment doesn't have near as much alcohol as just buying the real thing.
If it's trash you need to change the fuel filter.
If it were me I would do both.
Whoa! Hold on there. Before you go out buying some Isopropyl Alcohol, besure you know what you are getting. The alcohol found at the drug store is 70% alcohol with 30% water. Go to a paint store or hardware store and make sure you get 99% Isopropyl Alcohol, or you can use Methanol.
If it were me, I would drain as much gas out as I can and start fresh. Mix in some Techron Concentrate and a little alcohol, change the fuel filter and see if runs better. If not, then it could be plugs, coil pack, vacuum leak or a a multitude of other areas. Good luck.
Old Sep 19, 2003 | 05:50 PM
rqbrown's Avatar
Well,
Here's the story! Turns out #1 and #2 coil packs went out at the same time and have been replaced ALL for $0!
The SVT Asst. Svc. Mgr. says it happens sometimes. What are the odds ?!?
Anyway, the truck runs strong like it did prior to all this and I've gone over the truck for any indications of hot-rodding. I checked the usual "indicators". Came up clean!
Also, they put on approx. 10 miles for the test-drive. Hmm.
I appreciate EVERYONE'S input during this "ordeal"!
I guess I just had a good experience with this dealership - other's had warned me about going there. I had reservations about going to this dealership, but it's all good now.
Old Sep 19, 2003 | 05:53 PM
ShaneMcKenna203's Avatar
Congrats on getting it fixed. I figured that's what it was. I never thought it was bad gas. (did you even do any of those gas treatments or the fuel filter???) Again, congrats on getting it fixed. Shane
Old Sep 19, 2003 | 06:05 PM
rqbrown's Avatar
Shane,
I never tried any gas treatments, etc.
Thanks!
Ronald
But, both #1 and #2 CPs at the same time ?!?
Old Sep 19, 2003 | 06:15 PM
Don's Bolt's Avatar
Well that is a little strange, but these coil packs do go. Thats why I have a spare.
Old Sep 19, 2003 | 06:22 PM
LTNBOLT's Avatar
There is nothing nothing wrong with running 70/30 Alcohol. I have ran this before with 0 problems. Water does not cause a problem as long as it mixes with the gas. Without the Alcohol it just sets in a pocket until picked up by the pump. You then have a high concentration of water trying to fire.
Ever heard of water injection?
P.S. Glad you got your truck fixed.
Old Sep 19, 2003 | 06:25 PM
at least the coil pack went and you didn't launch a plug. What makes the coil packs go like that? Thanks, Shane
Old Sep 19, 2003 | 07:52 PM
rqbrown's Avatar
I'd be interested in knowing too, Shane...
Old Sep 19, 2003 | 08:27 PM
ChiDiver's Avatar
Earlier this week I filled up with BP/Amoco 93 down the street and 2 miles later my Scab started bogging and acting strange. I'm pretty certain mine is bad gas and I've noticed it is more common during season changes
Old Sep 19, 2003 | 10:55 PM
what did they say at the dealership?
Shane
Old Sep 20, 2003 | 03:56 AM
rqbrown's Avatar
The SVT Asst. Svc. Mgr. didn't say much. Just "it's one of those things" and his crew replaced them.
Dunno.
Ronald
