Help! EGR-related miss?
Fun new problem
Finally get my engine up and running and it lasts all of one week. Now, I have a miss (sometimes violent) at cruise. It happens at pretty much any RPM, as long as I'm off or only barely on the gas. Hitting a hill and adding load to the engine makes it go away. Hitting the gas a bit makes it go away. Someone suggested that I disconnect the vac line to my EGR valve to see if that helped. I did so and immediately the truck was running smoothly. So, I figure the EGR is bad. Well, I replaced the EGR valve, no luck. I also replaced the vac control valve (F63Z-9J459-AA) and the EGR differential pressure sensor (F77z-9J460-AB).
None of that helped. Still when the vac line to the EGR is connected, it runs like crap. Disconnect the vac line and all is well. What the he11 is going on here?
Finally get my engine up and running and it lasts all of one week. Now, I have a miss (sometimes violent) at cruise. It happens at pretty much any RPM, as long as I'm off or only barely on the gas. Hitting a hill and adding load to the engine makes it go away. Hitting the gas a bit makes it go away. Someone suggested that I disconnect the vac line to my EGR valve to see if that helped. I did so and immediately the truck was running smoothly. So, I figure the EGR is bad. Well, I replaced the EGR valve, no luck. I also replaced the vac control valve (F63Z-9J459-AA) and the EGR differential pressure sensor (F77z-9J460-AB). None of that helped. Still when the vac line to the EGR is connected, it runs like crap. Disconnect the vac line and all is well. What the he11 is going on here?
Could be the DPFE sensor, could be the silicone lines from the EGR tube to the DPFE, or could be your chip. Are you still running my chip with the new motor? I can shut the EGR off if you want, but it's good to have. If you replaced the valve and the solenoid, then something is causing the PCM to command too much EGR at cruise.
I have a problem with my EGR or something connected to it. I has a SES light come on, so I went to AutoZone and they scanned it and the code P0402 showed up with the description EGR Flow Excessive. Does anyone have any ideas as what to do about this????
Damon
Damon
Damon
Damon
Dan
Re: Help! EGR-related miss?
Originally posted by Nathan
Fun new problem
Fun new problem
