Does oil have a shelf life?
Old Sep 11, 2003 | 08:10 PM
VTSVT's Avatar
I found some Mobil 1 0w-20 but it looks like its been in the store for a long time. I'm pretty sure I saw it there at least 6 months ago, maybe longer. Can that stuff go bad? This is my first run with synthetic so I don't want to put in a bad first batch.
Old Sep 11, 2003 | 10:20 PM
cpeapea's Avatar
i wouldnt think so...but im not really sure
Old Sep 11, 2003 | 10:25 PM
player19's Avatar
There is no shelf life -- All you have to worry about is leaks/contamination
Old Sep 11, 2003 | 10:36 PM
MaxTorque02's Avatar
Motor oil typically has a shelf life of at least 3 years and even longer for unopened and properly stored oil. The Mobil 1 would be fine.
Old Sep 11, 2003 | 10:50 PM
greencrew's Avatar
First, Mobil 1 0w-20 is a new product out this year, released no more than six months ago. Second, unopened, oil has a shelf life of a good 7 years. Once you open the bottle moisture will get inside and all that changes.
Even still, old oil doesn't spoil or go bad. The biggest problem is a 10 year old quart of oil has the specs of 10 years ago which won't meet the required specs for your vehicle unless it's also 10 years old.
Old Sep 11, 2003 | 10:51 PM
player19's Avatar
Just a useless stupid observation about Mobile 1-- When you spray it with castrol super clean degreaser , it turns purple whereas regular motor oil doesn't.... really weird
AND if you think i have too much time on my hands you might be right, but I used to work in autoparts and cleaned up spilled oil a lot
Old Sep 11, 2003 | 11:40 PM
Tim Skelton's Avatar
Seems to last for quite a few years:
