NGK TR-6 with a 2#er?
Old Sep 11, 2003 | 12:06 PM
Konig's Avatar
Well with all the "plug spitting" talk lately, I decided my luck is probably likely to run out soon. I have about 36lk miles (just out of warranty) and have never checked the plugs even once. I figured I would have them changed instead of just checking them. I dont really like what I hear about the Densos, havent heard many bad things about the NGKs, but anyhow.. I have a 2# lower and its an everyday driver with mild track use... what would be the better plug?
Old Sep 11, 2003 | 02:51 PM
eatoncharged's Avatar
Banned
I don't want to say which is a better plug because honestly I don't know. I can tell you this however, I bought a set of Densos did all of the work to put them in and maybe not even 500 miles later I started getting a misfire. The only way that stroy really relates to you is the fact that I have run my TR6 plugs for near 17000 miles without a single problem, and and everyone of those miles has had extra boost. If you are only going to run a #2 pulley I wouldn't even worry about plugs. I think and most should agree that the best bang for the buck as far as plugs go are the TR6's and they hold up really good.
Old Sep 11, 2003 | 02:56 PM
LightninSVT's Avatar
Ive been running the Denso IT20's for about 10K with a 2#er and no problems yet....
NGK TR6 are the ones I would go with if you went with that brand.
Jon
Old Sep 11, 2003 | 03:41 PM
Konig's Avatar
Well Im going to change them regardless, I figured it would be the NGKs... but I was wondering if the TR-6es are appropriate for my boost level, especially since eventually I will be running 4# extra total. (2# upper + 2# lower)
Old Sep 11, 2003 | 03:48 PM
Don's Bolt's Avatar
For 4# of boost TR6's would be perfect, gap them at .040
when you put the plugs in, when you think they are tight give them a extra little snug.
You will be all set then.
easterisland's Avatar
You should talk the person you're getting the chip from. IMO the TR6's would work fine. Heck I used TR6's with 18psi boost for awhile.
Old Sep 11, 2003 | 04:00 PM
Konig's Avatar
Chip? .
I dont currently run either of my chips...I may soon, but for now I have them pulled. So I should be ok at 10-12#s with the NGKs for now then? I know they are perfect for 4#ers..but I wont be doing that until november or december when its colder outside and I head back to the track.
