Gatorback belt part #
Old Sep 11, 2003 | 01:34 AM
rodcobra's Avatar
I'm getting a 4# pully next week and i want a new belt whats the part number for that belt. Thanks
Old Sep 11, 2003 | 01:48 AM
Ayrton's Avatar
4080675--blower belt with 4-6lb lower pulley
Old Sep 11, 2003 | 08:16 AM
tommylightning's Avatar
With the tab broken, the above suggestion would work. If not I would use the 4080680 for the 4# (unless you changed the upper) and a 4080685 for a 6# lower.
We have them both (and others) in stock for $37ea, give us a call @ 609-567-5774
Old Sep 14, 2003 | 11:35 PM
rodcobra's Avatar
Thanks guys
Old Sep 14, 2003 | 11:41 PM
promodlightning's Avatar
Hey Tommy, how much for a Gatorback...Pete
Old Sep 15, 2003 | 01:46 AM
Ayrton's Avatar
Pete don’t you have a RR upper pulley? If you run the Gatorback with an ultra grip pulley it chews up the belt pretty good. RR recommends using a Gates belt with the ultra grip pulley
Old Sep 15, 2003 | 06:48 AM
Gaterback belts, $35ea It depends on the upper pulley size it you should use a Gates belt or not. If you are running smaller than a 2.7 upper, run a Gates.
Old Sep 15, 2003 | 11:10 AM
Good point..Thanks
