Weird vibration?
Old Sep 10, 2003 | 10:01 PM
Skip's Avatar
Weird vibration?
I have a vibration that can only be felt during acceleration and sometimes when slowing down. I feel it most in the gas pedal. I checked the usual stuff like blower hitting firewall, bad pulley bearings etc. Could it be the convertor? Could a motor mount cause it? It is very slight, but anoying. Anyone have any ideas? Thanks in advance, Skip
Old Sep 11, 2003 | 09:28 AM
LIGHTNINROD's Avatar
I d/k(but this will TTT) but my first thought was your driveshaft..............
Dan
Old Sep 11, 2003 | 10:10 AM
Skip's Avatar
Still does it when stopped in gear also. Skip
Old Sep 11, 2003 | 10:56 AM
Dman25's Avatar
Umm, Check ure engine mounts, maybe they are broken. On my old car which was an eclipse, my engine mounts where broken and i had the same symptoms.
Old Sep 11, 2003 | 11:55 AM
lightning00n93cobra's Avatar
Check the throttle cable istelf sometimes with the air kits etc the cable rubs on some of the brackets for the box. this will give u a vibration in your gas pedal.
Old Sep 11, 2003 | 12:10 PM
retics4me's Avatar
Re: Weird vibration?
one time my throttle cable was routed through behind the powersteering resivoir and it was like that .
Old Sep 11, 2003 | 08:45 PM
Skip's Avatar
Thanks guys!
Throttle cable was resting on the power brake vacuum line. Never thought that it would vibrate that much. Moved the cable and the vibration seems to be gone. Wow! Such a simple thing. This board is very helpful. Thanks again, Skip
Old Sep 12, 2003 | 12:26 AM
DAMN IM GOOD
Old Sep 12, 2003 | 01:44 AM
Skip's Avatar
