Qusestion for Sal@PSP
Originally posted by easterisland
They also claim that the water/alcohol will clean the engine also. I don't know if that is true, but it is one of the claims.
I prefer the SMC Ent kit as it is specifically made for the lightning with a new boost solenoid.
I had my injector on top of the entry to the blower but it drew water constantly...acted like a siphon...Id go through 2 1/2 gallons of water a week.....unless you put a selenoid on a switch activator, Id run the injector in front of your t-body....Aquamist instructions say to run it that way....this way I go through a half cup water a week if that and it doesnt draw water while Im cruising...this is whats recomended and it works...I am planning on putting a second injector in the system on the other side of intake boot....heres a pic....
Promod...Nice set-up! Question though, do you think if I put the nozzle in the PSP nitrous plate that it would siphon too much?? And what do you dillute it with? I am looking to get this ASAP but would like to talk to someone with expereience. Also, do you have anymore details on your dual oil seperator?? I love that and would love to do it!
Thanks Promod.... That answered almost every question!!
So you suggest the tube where your s is huh??!!! Second, how did you make the dual seperators? Looks killer!!! Thanks againf or the info
I was thinking about a water kit because it would be cheaper to use for daily driving. I would like to run higher timing than the 12.5° with 93 octane.
to answer Easters question would be a simple Yes.....Im living proof.....I run 14 degrees of timing with 21.5#s of boost everyday and I adamently believe that I could get away with more timing and boost by way of a 50 to 60% alcohol mix....
