Can anyone help a brother out with a bolt?
I busted the head off one one the bolts that holds the coil pack in place. I got it out but I still need to replace the bolt and none of the Ford dealers around me have one. One parts guy told me to go to home depot. But me being the **** L owner that I am, I want and need the exact bolt that comes with the motor. Does anyone have one or know where I can get one? Id appreciate it. Thanks.
Yeah seriously, buy the bolt from anywhere and just order the correct one. I am sure those horrible days you had to go thru with the wrong bolt in there will be a distant memory once you get the right one.
Just playing with ya. I personally don't have one, but like was stated above I am sure a tuner has one lying around. Sorry about the breakage. -Mat-
TORQUE TO YIELD
Just playing with ya. I personally don't have one, but like was stated above I am sure a tuner has one lying around. Sorry about the breakage. -Mat-TORQUE TO YIELD
Originally posted by SVT F15O
I am sure those horrible days you had to go thru with the wrong bolt in there will be a distant memory once you get the right one. :
What is nice about the stock bolts is they have a washer built into the head. The only aftermarket bolts I could find local were too long and had 8mm head and no washer built in.
Don't ask me why, but I have a extra
send me your address and I will send it out to you
I guess I am not the average L owner.
dhco@rcn.com
dhco@rcn.com
Also incase you want to find something local
the bolt you need is a 5mm x .8 thread pitch x 27 mm.
ford part #
N606500-S8
Pkg of 2 bolts
Cost about $3.25
ford part #
N606500-S8
Pkg of 2 bolts
Cost about $3.25
