KB Zilla
KB Zilla
Sorry...had to do this post cause there's no PM's
anyway, I was lookin at your sig. how much boost you running through your KB, and also when you ran that time, were you on slicks?
thx
-Mike
thx
-Mike
Im pretty shure he ran slicks on his best time with the eaton. He dynoed the other day on like 492 rwhp / 572 rwtq @ 18 lbs
446 rwhp / 506 rwtq @ 14 lbs. Not shure what boost he plans on running all the time.
Re: KB Zilla
thx
-Mike
thx
-Mike
My best time in my sig was with 18lbs on slicks, 90 degree and high humidity that day.
And latemodelracer is correct with my dyno #'s
Btw: Next time at the track should be interesting when the weather gets cooler, 11's will be within reach. Using some of the advice from fellow members, I am going to try some different launch techniques to try get my 60' times down.
Originally posted by LatemodelRacer2
i think it was 11.4 on 14lbs and 11.8 or 11.6 on 18lbs. He has a reflashed PCM so it adjust his A/F ratios pretty well.
Who does these reflashes?
Is there a distinct advantge to a reflash -vs- a chip?
I havent put much thought in them since iv had a chip for almost two years and it was working fine. I have heard from the boards that it is supposed to adjust your a/f ratio to wheere it always stays close to a set number no matter what your mods are. I think the guy who does them is mark @ Blue oval performance.
Originally posted by SLVRNBLK
What pulley configuration is gettin you 16psi?
18psi?
What were your A/F on the dyno at:
14psi?
18psi?
Just curious as I'm trying to get my KB dialed in also.
18psi?
14psi?
18psi?
A/F's were 11.2 with 14lbs.
and 11.6 with 18lbs.
I use a 6lb Metco Lower (9" pulley) and
3.00" upper = 18 lbs
3.25" = 16 lbs
3.50" = 14 lbs
And yes, I have a Reflashed computer. Mark @ BlueOvalPerformance.com can hook you up. The guy he has doing the Reflashes knows his ***** !!
