Bad 1/4 mi. times for mods??
Little dissapointed with my times tonight, I thought maybe I would have been closer to my 12.99 or something....
Street side of chip:
60' 2.035
1/8 8.613 @83.75
1/4 13.326 @104.57
"Race side":
60' 2.140
1/8 8.750 @83.34
1/4 13.472 @104.42
The first time I let into it and then got on it, and I thought that was a bad time, so the next time i just pretty much got on it out of the hole. I've heard of guys in my area running just a chip and air kit running 13.0's, what gives???
BTW: 63 degrees
80% humidity
Jon
60' 2.035
1/8 8.613 @83.75
1/4 13.326 @104.57
"Race side":
60' 2.140
1/8 8.750 @83.34
1/4 13.472 @104.42
BTW: 63 degrees
80% humidity
Jon
I would think with your mods you would do a little better but your 60' is killing you a little. Where did you run at? I am going down to Delmar Sunday to race. It's cool there because there are only 2 L's, mine and another guy. Bunch of GM's and mustangs.
Cecil, I am going to try and get up there Wed. I hear they are having a test-n-tune. Delmar is just a few miles past Laurel. It is on the right of the highway. It has a sign out front , US 13 Dragway, but you can miss it if your not careful.
Not bad for a Chip-n-2lb Pulley LightninSVT
CONGRATS
But with that extra 25HP or so you got
(via Elec Fans + Water Pump)
I'd expect more,
plus Cecil is a "Give me" for a good 2/10 th's
compared to most other tracks.
What Timing are you running ? (you need 16 minimum)
Did you do cool downs between runs ?
CONGRATS
I'd expect more,
I really don't know what the timing is at, I had the truck up at Johnny's and he datalogged it. I got two runs in the 2 1/2 hours i was there, so yeah it was def cooled down.
Traction bars maybe?? what do you run stock 18's psi at?
Jon
Jon
I found my F-1's hooked best at 25psi
I actually got a 1.8 on them
tons of 1.9's
and one 2.0
Now I use Hoosiers,
my 60's are 1.6 with juice 12.0-12.3's
and 1.7 on all gas for 12.7 - 12.8 runs
Jon,
Dont be disappointed or fustrated, the power is there
I spent an entire summer running 13.1 - 13.3
with 6lbs of boost, YES 6 LBS OF PULLEY
But that was when my truck was brand new and I asked
for a extremly mild tune to break it in.
I was sooooooooo fustrated week after week.
When I questioned my tuner, I found out all I had was 2 degrees above stock timing
Once I hit 5000 miles I stepped it up to 16 degrees,
tuned down my truck to 4lbs of Pulley
and immediatly ran a 12.8
It's been nothing but 12's ever since
I backed up my 12.7's + 12.8's with a simple Filter chip n 4lb pulley
To prove my point, I did some testing this yr at the track,
I ran a 12.7 + 12.8 on my 16 degree program (all gas)
then switched it to stock timing and ran a 13.0
IT'S ALL IN THE TIMING and mine needs a lot
16 is very safe AND THE MINIMUM YOU NEED
Anything less and your ET's will suffer no matter what mods
I now run 18 degrees 24/7 on the street
I've been running it a few months now, so I know
it's trouble and detonation free. (Pulls like a mo fo)
I also kept my old reliable 16 degree program
(That's for Juice, long WOT pky runs, and winter street driving)
Next Month when it cools, I'll get some new ET's
tons of 1.9's
and one 2.0
Now I use Hoosiers,
Jon,
