L is sputtering
Old Sep 4, 2003 | 08:21 PM
therealgeronimo's Avatar
Unhappy L is sputtering
While turning a corner from a stop sign this evening my truck began to sputter. Almost like it was either too rich (pooling of fuel though never seen it in a efi engine) or it wasn't getting enough fuel. I was at 1/2 throttle when it happened. I let out of it and it came back to life. Any ideas? Fuel filter maybe? I am going to change it tommorrow before I go to work. It drove fine after that.
Old Sep 4, 2003 | 08:59 PM
LIGHTNINROD's Avatar
It could be the fuel filter if it has 8,000 miles or more on it. It could be the IAC if you were at idle rpms.
Since you have a 99, it could be a fuel pump line clamp that has come loose---hope not .
Dan
Old Sep 4, 2003 | 09:12 PM
eatoncharged's Avatar
Banned
If I had to say, it might be a coil pack. Have Autozone do a diagnostics test on it.
Old Sep 5, 2003 | 12:01 AM
Grandmastr's Avatar
check ur fuel filter, replace it, than ur fuel pressure, definalty get a free readin from autozone, i had some wat the same problems like u and it was my coil pack
Old Sep 5, 2003 | 01:55 PM
Changed the fuel filter today and noticed that the rear axle seals on both sides were leaking and I mean leaking bad. Replaced them too and now the L seams to be back to normal. I think the guy who used to own my L put too much rear end oil in the rear b/c when I opened it to check the level it spewed out. I think that caused the seals to go bad. Thanks for the help.
Old Sep 6, 2003 | 01:12 AM
Grandmastr's Avatar
got any pics of ur seals leakin , i wanna see this
Old Sep 6, 2003 | 03:53 PM
No I didn't take any pics due to the fact I was planning on just changing my fuel filter so I didn't take my camera with me to my friends shop. If you have never seen seals leak I might can find a pic of another type vehicle to scan and show you in one of my repair books that are scattered all over the house.
Old Sep 7, 2003 | 09:09 AM
DL's Avatar
DL
Autozone will do this for free???
