A/C supercooler is reality->>
Old Aug 26, 2003 | 03:57 PM
JeffsLightning's Avatar
It's already installed on one Lightning with 10 more kits being fabbed....
http://www.fordtruckworld.com/forums....ten?id=197303
Old Aug 26, 2003 | 04:00 PM
SpankDog's Avatar
Banned
Old Aug 26, 2003 | 04:01 PM
Flying Mofo's Avatar
Banned
Idled for an hour and only got to 73 degrees? Coletti's hits the 40's. I want to see how cold it get while driving. I noticed he didnt post any pics either.
Old Aug 26, 2003 | 04:09 PM
SpankDog's Avatar
Banned
Greez Lightning
Old Aug 26, 2003 | 04:13 PM
MaxPower's Avatar
Hell yea!
I want one! ...Christmas IS coming....
Old Aug 26, 2003 | 05:00 PM
Coldie's Avatar
Not exactly the same...
Not exactly the same as the Ford version, in fact quite a bit different.
Ford:
Chills a small resevior and releases it at WOT. Doesn't affect AC and can be used at the track because AC compressor doesn't need to be on...
This one:
Inline chiller for IC fluid. On constantly. Constantly takes away from AC effectivness. AC compressor running on the track is a big no-no.
Still get a big from me, but not quite the same...
Coldie
Old Aug 26, 2003 | 05:14 PM
eatoncharged's Avatar
Banned
if i were to fab something, id use a seperate refrigeration circuit and use some r-23 or something like that, at least r-12 and it might work a little better.
Old Aug 26, 2003 | 05:25 PM
Silver_2000's Avatar
Re: Not exactly the same...
Ford:
How does the Ford version ( that has been rumored to be shelved ) cool the system if it doesnt use the AC compressor ? It has a separate compressor ? Or does it use unobtainium ?
I understood it used the A/C but stored the cool to avoid running A/C it on the track. In other words you could prechill the system then turn off A/C and stage and run with A/C off
Doug
Old Aug 26, 2003 | 07:20 PM
Coldie's Avatar
Ford's system...
You're right Doug.
I meant that the Ford system doesn't ALWAYS use the compressor. I'd imagine this system will definetly hurt your AC output whereas the Ford system your AC would be a little warm for a couple of minutes after a WOT run...
Coldie
Old Aug 26, 2003 | 07:27 PM
Re: Ford's system...
You're right Doug.
Coldie
Old Aug 26, 2003 | 11:24 PM
Tim Skelton's Avatar
Well, that depends on what you call "the track." On the road courses I run, there are no rules against using an A/C (at least none I'm aware of).
Old Aug 26, 2003 | 11:28 PM
promodlightning's Avatar
Old Aug 27, 2003 | 12:29 AM
Unoid's Avatar
I wanna see some hp/torque numbers with that thing and how long the extracooling lasts, I'd much prefer a 40hp blast for 30 seconds comapred to 10hp for 5 minutes.
Old Aug 27, 2003 | 09:48 AM
lurker's Avatar
This one:
I would think that as long as you got the fluid cool, you could shut the compressor off for the run.
Old Aug 27, 2003 | 11:23 AM
unclemole's Avatar
$1000 plus installation!
