Settled springs, the pictorial. :)
Old Aug 25, 2003 | 07:51 PM
thepawn's Avatar
Talking Settled springs, the pictorial. :)
I think the only remaining board member that has the ROUSH install longer then me is SixPipes, so I figured I'd post up my measurements on how my suspension has settled out. This is a full weight truck, nothing removed, with a ARE-II bedlid and subs. :)
Front Wheel (centerline to fender):
Rear Wheel (centerline to fender):
Front Lip:
Old Aug 25, 2003 | 07:52 PM
thepawn's Avatar
Frame:
Hitch:
Mufflers (lowest point)
Old Aug 25, 2003 | 07:53 PM
thepawn's Avatar
Exhaust tips:
No more wonder as to why I won't put on a Ford Racing tranny pan.
Daniel
Old Aug 25, 2003 | 08:37 PM
REDY2KL's Avatar
Old Aug 25, 2003 | 08:42 PM
REDY2KL's Avatar
How about pics of the whole truck???
Old Aug 25, 2003 | 08:44 PM
MISTERgadget's Avatar
But you could put on a moroso tranny pan. It measures 3.642 inches from top to bottom, just like the stock pan.
How would these measurements compare to a truck on Goodyear f1s? I know the pirelli's you run are slightly lower in overall height.
Thanks.
Old Aug 25, 2003 | 11:59 PM
SpankDog's Avatar
Banned
now if i just had the roush suspension i would be happy.
Old Aug 26, 2003 | 12:28 AM
thepawn's Avatar
Thanks.
I've been eye'n up that Moroso pan since you put picks of it up, I think I may go that route. There was also one finned one (B&M?) that had no increase in clearance too.
My Pirelli's are .4" shorter then a stock tire...Spike's last post about the stock centerline height for the wheels was 19" for the front and 20.25" for the rear, so spring height alone I'm 2"/3.25" lower then stock.
The tires drop it another .4" inches...my new tire selection (chip required) looks like it will be about 1.4" lower on tire size.
Daniel
Old Aug 26, 2003 | 12:30 AM
thepawn's Avatar
REDY2K:
Old Aug 26, 2003 | 12:49 AM
REDY2KL's Avatar
Pawn thanks for the pics. You have an awsome truck!!
Old Aug 26, 2003 | 03:59 AM
Flying Mofo's Avatar
Banned
I would like to add that kit over the winter. It looks really good. Do you scrape at all on driveways?
Kickass truck Daniel.
Old Aug 26, 2003 | 11:20 AM
thepawn's Avatar
Occasionally (4-5 times) I've scraped the hitch on a driveway, but generally it still clears things. (seems 4" is the optimal height)
I have scraped the front valence on one curb, but otherwise nothing.
Daniel
Old Aug 26, 2003 | 04:15 PM
SVT_KY's Avatar
Daniel
Did you see the NEW "R" compound Nitto's in MM & FF ???
Sweet
Cliff
Old Aug 26, 2003 | 04:39 PM
Banned
So thats a 4" drop setup? Stock Roush?
Old Aug 26, 2003 | 05:07 PM
captainoblivious's Avatar
Little less the 4", remember he has that heavy ARE lid, plus knowing Dan his got alotta stuff in the back. So you're talking a few hundred lbs. extra which brings it to the 4" drop.
