Lowering springs and 2'' shackles??
I installed 2'' lowering shackles on my 03 and im wondering what lowering springs would do for appearence?
Also,would it be a big pain in the azz?Do any of u guys have pics of lightning with lowerd springs and 2''shackles?(2003).
Just subscribing. I'm curious too Frank (and new to the L world). Did the rear shackles even out the stance of your truck? I know these monsters sit a little higher in the back. I was thinking about getting a pair of shackles myself (and possibly lowering springs too).
BTW, I see you are a local guy. Hopefully, I'll be getting up to Towers this Friday. See you around man.
Brian
Brian
I just today installed the Hotchkis 2411 rear springs. These are a 2" rear drop and have a 300 # rating. If you put these on it will lower a 03 about 3". I tried to put these on with my 2" drop shackles but only on the first hole which would give me a 32" drop (4" on an 03) bit it was fighting to get on and looked like it was going to bind. So I'm back a 2" rear drop with springs only. Which is good. This way I don't have that much sway in the shackles.
hieght outcome?
I used the jdm 2'' lowering shackles and got a good 1.5 out of them but still a little high in in azz end.I SAW A GUY AT TOWERSHOPS FRDAY WITH A 03 AND IT WAS DEFINITLY HIGHER THAN MINE IS NOW.Im at towershops almost every friday parked with the rest of the lightning owners(10-25) most of the time.Really cool place.
Originally posted by Stormyday
If you don't carry too much heavy stuff you can remove the second spring up from the bottom.
This drops it about 3/4 inches, at least it did on mine and gives a softer ride.
Chris
Chris
Originally posted by potac
MISTERgadget,
What drop does the Sonic Blue L have in your pictures?
MISTERgadget,
It has the roush suspension kit
www.roushparts.com
