KB dyno charts
Old Aug 23, 2003 | 07:32 PM
Six Spd Z28's Avatar
Registered User
Originally posted by SVT F15O
I am quite suprised I am that brave myself. I just figure what the hell. If it blows and I have the money to fix it, it gets a nice built block. If I don't have the money it sits on the side of my house until I save up. I just wanna see how fast I can go on a stock block. Anyone not what the fastest is>??? -Mat-
Thats my way of thinking also. I would like to know the fastest on a stock block also.
Old Aug 23, 2003 | 07:53 PM
Dan_03Lightning's Avatar
Here are the mods:
KB
6lb
2lb
Diablo Delta, custom template and tune
Lunar Gauges
Dual Pillar Pod
JLP Ram Air
Accufab 90 mm single blade
Ported/Polished Plenum
Autolite AR 93's
Oil Separator
Fluidyne Heat Exchanger
Dual 55lb Cobra Fuel Pumps
Factory Tech Valve Body
Ford deep trans pan
Dynatech long tube headers
High flow single cats
Magnaflow Cat Back
T Trak Traction Bars
JLP 3" Rear drop shackle
PSP Drive shaft loop
Nitto 555r"s
I am not having any luck trying to post the Dyno sheet. Tomorrow I will create my own site and have it available there. The results were (on a Mustang Dynamometer)
Max Power: 411.0 @ 4750 RPM
Max Torque: 507.2 @ 4000 RPM
Add 16% to mimic a Dyno jet. The curves are perfect, very smooth and I am very happy with her. She is an absolute beast!
I will get it set up tomorrow, I am pushing 15lbs of boost and I was told that my engine should grow in power. She only has 1500 miles on her.
Have a great one!
Dan
Old Aug 23, 2003 | 09:05 PM
Rob_02Lightning's Avatar
@ SVT F15O
niiiiiiiiiiiiiiiiiiiiiiiice #'s
Old Aug 23, 2003 | 11:40 PM
Skip's Avatar
Boost
My truck does the same thing with a K/B. Boost holds at 12 pounds then instantly jumps to 16 above about 4500. I have a stock lower and a 3" upper. Skip
Old Aug 23, 2003 | 11:47 PM
SVT F15O's Avatar
Re: Boost
Well now with a 3" upper and a 4LB lower I see a constant 15-16 pounds all the time, no more spikes. -Mat-
Old Aug 24, 2003 | 01:02 AM
Skip's Avatar
svt 150
Do I have 12 # or 16 # of boost ? I really don't know what to say that I have. Maybe droping to a 2.75 upper will stop the spike. Maybe I should try a 4# lower and a 3.50 upper. It just never ends. Skip
Old Aug 24, 2003 | 08:52 AM
I get the same spike you are refering to and I have the 6 lb lower (9.25) and 2 lb upper (3.25). And I lost one lb once I put the long tubes, highflow cats and magnaflow cat back on.
I am getting the 15lbs, but it builds to that. Moves to 12 really fast then builds to 15.????
Dan
Old Aug 24, 2003 | 09:48 AM
Don's Bolt's Avatar
Here is mine
Mods
Built longblock
8# lower 3.2 inch upper
headers
high flow cats
Magnaflow mufflers
KB
Bigger injectors
25 fuel pumps
adjstable fuel pressure regulator
Electric fan
Cobra Water pump
single blade throttle body
breather
Monster box
Old Aug 24, 2003 | 10:02 AM
easterisland's Avatar
Re: Here is mine
Originally posted by Don's Bolt
Mods
Built longblock
headers
high flow cats
Magnaflow mufflers
KB
Bigger injectors
25 fuel pumps
Electric fan
Cobra Water pump
breather
Monster box
I wondered how you were supplying fuel to that beast...
Old Aug 24, 2003 | 12:43 PM
Skip's Avatar
Don
You win!!!!!!!!!!!!!!!!!!! Skip
Old Aug 24, 2003 | 02:52 PM
Suavy's Avatar
Don that rocks!
I'm headed back to see Jim & Justin by the end of this month! Just want to stand in your shadow!
Peace, Suavy
Old Aug 25, 2003 | 07:07 AM
whip's Avatar
Re: Re: Here is mine
Haaa, gotta admit, thats pretty funny!
