Intercooler flow path
Old Aug 22, 2003 | 03:16 PM
Daves00L's Avatar
Question Intercooler flow path
From looking at intercooler tank, all the activity is on passenger side. i am going to insulate the line FROM the intercooler tank TO the engine to reduce engine heat absorbtion, although it's probably not much. which is the line TO the engine, the one on the passenger side ?
thanks,
Dave
Old Aug 22, 2003 | 03:36 PM
LatemodelRacer2's Avatar
the flow goes from
tank to motor
motor to exchanger
exchanger to tank
i think this is right
Old Aug 22, 2003 | 03:39 PM
easterisland's Avatar
If you run 5/8th inch heater hose from the lower heat exchanger to the intercooler you will probably be better off. I routed mine as far away from the supercharger as possible.
Old Aug 22, 2003 | 06:45 PM
ChildsPlay3's Avatar
Keep us posted but dont expect dramatic results. Heat doesnt come from engine heat, it comes from the 200+ degree air temps out of your blower.
