Anyone running linelock?
Old Aug 21, 2003 | 08:24 PM
bad00's Avatar
Question Anyone running linelock?
What kit do you have, and how was the install?
Old Aug 22, 2003 | 10:49 AM
bad00's Avatar
TTTT
Old Aug 22, 2003 | 12:01 PM
bad00's Avatar
I guess nobody is running linelock I just ordered my kit from PHP.
Old Aug 22, 2003 | 12:28 PM
1BADTK's Avatar
I have built, installed several using the Hurst Roll Control and new tubing.
Old Aug 22, 2003 | 01:40 PM
bad00's Avatar
Did you have to use two solenoids,one for each wheel? Did you have any problems with the ABS/light?
Old Aug 22, 2003 | 01:47 PM
Flying Mofo's Avatar
Banned
If i could i send you $$ would you build me the brake line needed to fit into the ABS unit? I already have the solenoid. This is my only obsticle at this point. Thanks.
Old Aug 22, 2003 | 01:59 PM
1BADTK's Avatar
Single Solenoid between the ABS and brake master cylinder for the front brakes. Flying ****, its hard to build without the truck, but if you give me a year model I can come so close, you might need to "TWEEK" the tubing line a tad at install. I will need a new brake line like the one that runs from the master cylinder to the ABS for the front brakes. I can get that here locally, and one Hurst Roll Control. PM me and I will fill you in on the details.
Old Aug 22, 2003 | 02:08 PM
Banned
Thanks, ill send you an email since PM's dont work on this site.
Old Aug 22, 2003 | 02:11 PM
bad00's Avatar
"Single Solenoid between the ABS and brake master cylinder for the front brakes"
Hmmm, the kit I ordered has two solenoids? oh well i just hope it works and dosnt screw with the ABS.
Old Aug 22, 2003 | 02:21 PM
Banned
I dont like Pauls 2 solenoid kits. Ive seen track officials frown on it as well. It can be done with one and cheaper as long as you can get that brake line made up.
Old Aug 22, 2003 | 02:27 PM
Six Spd Z28's Avatar
Registered User
I wish someone would post a how to on this subject....with pics of course
1BADTK's Avatar
You have mail. or should I say "You Got Mail"
Old Aug 22, 2003 | 02:30 PM
C BROWN's Avatar
Any chance I could get you to make me one also; I have a 2002. I just don't have the correct tools for making the lines correct. If you can e-mail me caseybrown@bellsouth.net and fill me in on the details
Old Aug 22, 2003 | 02:38 PM
Banned
Thanks again Andre
Old Aug 22, 2003 | 02:39 PM
bad00's Avatar
Why would track officials frown on a 2 solenoid setup?
