Trans Fluid ?
Old Aug 16, 2003 | 07:46 AM
SLICK0478's Avatar
Trans Fluid ?
I just changed the trans fluid in my truck it has 4x4 pan I know others say it takes about 7 qts I only used 6.25 if that anyone else use the same amount I also realize it is like living on the sun right now in NJ maybe it will be a little on the low side in cooler weather trans temp was running about 155-160 and fluid level in do not add section of stick
Slick
PS if you got a Costco by you mobil ATF is like 9 - 12 buck for a case of 12 and mobil one oil 22 for a six pack
Old Aug 16, 2003 | 09:39 AM
Dan_03Lightning's Avatar
I did the same thing, and came up with the same result 6.25 to 6.5. Warm or hot my trans stick is showing full.
I haven't looked at it cold. Ya gotta love Costco.
Dan
Old Aug 16, 2003 | 05:09 PM
promodlightning's Avatar
I did one last week with a 4x4 pan and it took 7-8 quarts..
Old Aug 16, 2003 | 10:47 PM
SpankDog's Avatar
Banned
whats the proper way to check the fluid? engine running in parK? or what?
Old Aug 17, 2003 | 06:07 AM
SLICK0478's Avatar
I guess I will have to check this when it cools down a bit, but I also didn't wait for the dripping to completly stop when changing but definately no way another 1.5 qts +/- would have come out.
I went to alldatapro.com and looked up it says 4x4 16.7 ltrs and 4x2 16.1 ltrs so I figure 10 ltrs/qts for converter and either 6.1 qts or 6.7 qts for pan I think it is like 998ml(1000ml=ltr) to a quart or pretty close to it
Thanks Again
Slick
to check start truck shift from park thru gears a few times then let trans go up to normal operating temp then check road test check again
Old Aug 17, 2003 | 12:08 PM
BMWBig6's Avatar
Re: Trans Fluid ?
WHAT?!?! You can get 12 quarts of Mobil 1 ATF (sythetic) for $9-$12? Or did you mean just the regular Mobil ATF (dino sauce)?
