Air/Fuel Gauge Wire??????? (pics)
Old Aug 15, 2003 | 01:31 PM
Krix330cic(NJ)'s Avatar
Exclamation Air/Fuel Gauge Wire??????? (pics)
looking to tap into correct wire. Think it was promodlightning that recomended Blue w/White stripe or Red w/Purple stripe or Blue w/Red stripe.
Do i even have the correct location???
Old Aug 15, 2003 | 01:56 PM
Flying Mofo's Avatar
Banned
Yes you do, thats the main computer harness. I still would be tapping off the actual o2 sensor myself.
Old Aug 15, 2003 | 02:01 PM
tommylightning's Avatar
I tap off the driver side (bank1) front o2 sensor, the black wire.
Old Aug 15, 2003 | 02:20 PM
SpankDog's Avatar
Banned
its like..........right here and stuff
Old Aug 15, 2003 | 02:56 PM
maybe i will just get the harness... but back to my original question, that big 'ol jumble ***** of wiring is where these other wires are to tap into?
Old Aug 15, 2003 | 04:03 PM
jarmstro's Avatar
Also be sure you tap on the O2 sensor side as Michael pointed out in his picture. If you screw up all you have to replace is an O2 sensor
Old Sep 14, 2003 | 01:07 PM
lightning5.4's Avatar
Ox2 sensor
Granted nobody wants to butcher up there wire harness but keep this in mind, the Ox2 sensors use outside air as a reff. to judge rich or lean, the 4 wire Ox2 sensors get this outside air through the strands of wire inside the insulation (this is true from Ford elect class) so if you splice into the Ox2 pig tail and solder the wire you stop the air flow and can affect the reading of your sensor. This is just something to consider. the smaller connector above the large conn is where the Ox2 wires are.
Old Sep 14, 2003 | 01:37 PM
MISTERgadget's Avatar
This is a beautiful thread. Spank and **** offering help with pictures and explanations.
I miss them already.
Old Sep 14, 2003 | 01:43 PM
Odin's Wrath's Avatar
Plug and Play
