Diablosport Predator
Old Aug 15, 2003 | 01:20 AM
hslightnin's Avatar
Power Enrichment (Fuel): Will adjust from -5% to +5% for PE mode
ive been holding out on a chip since it will eventually come out but i was just thinking about it.
it doenst seem like 5% increase would be enough to add alot of boost or other mods are chips limited to 5% also or what
Old Aug 15, 2003 | 01:31 AM
promodlightning's Avatar
I have a Mafterburner and granted I have cams and ported heads, but Im adding 22% more fuel across the board plus whats in my chip...a 5% increase is nothing....
Old Aug 15, 2003 | 08:36 AM
Rob_02Lightning's Avatar
Re: Diablosport Predator
HS
That adjustment is AFTER THEY put a CUSTOM program on it for YOUR LIGHTNING and YOUR MODS.
So when you download the Custom Program on the Predator into the service port, you'll have CUSTOM Shift Points, A/F, Timing, Transmission Pressure, Etc...
Then you can tweak it "IF NEED BE" 5% in either direction should be plenty. Plus like a Chip you can always have a differant program put on it but meanwhile you still have your custom program installed And this will be done by downloading a new program into it via the internet (I believe)
You'll have all the options and adjustments you can possibaly want with the Predator.
Remember WE ARE NOT TUNERS
If they allowed us to do it from scratch, we'd be reading blown Motor Post daily
I think it's gonna be awesome
Old Aug 15, 2003 | 09:08 AM
crockett59's Avatar
You know I was wondering about that myself. I don't want to have an problem with trying to tune it myself. But tweaking would be cool. I wonder if it will cost anything to download a new program?
Old Aug 15, 2003 | 09:41 AM
Here's the info right from Runnin' With the Devil
Predator Update:
Originally posted by RWTD
I wanted to update everyone on the very latest information, as of today, on the DiabloSport Ford Gas Predator for the Lightning, Harley, and Cobra vehicles. I encourage replies and questions, as well as thoughts and opinions. Per DiabloSport, I am expecting a release date next month. If you would like to be placed on a contact/waiting list, please see below.
DiabloSport Predator Part # U7142 / U7158
Applications:
- U7142 - 2003 4.6L 4V Supercharged Mustang SVT Cobra
- U7158 - 1999-2003 5.4L 2V Lightning / Harley Davidson Supercharged F150
Pricing: The MSRP is $495, and I will sell at the lowest price possible, per DiabloSport Dealer Terms of Agreement, which is $419 OTD, as well as include FREE UPS Next Day Air Shipping.
Features
Dyno Tested Performance Tunes:
- Diablosport has generated dyno tested tunes for 2003 4.6L/4V Ford Supercharged SVT Cobra and 1999-2003 5.4L-2V Ford Lightning and Harley Davidson F150 applications with Supercharger.
- Average power gains are in 20-30 HP in the Supercharged SVT vehicles.
Diablosport Predator Performance Tunes Re-Map:
- Fuel Curves
- Timing Curves
- Extend Speed Limiters
- Extend Rev Limiters
- Part and Full Throttle Shift Points
- Shift Timing
- Shift Pressure
Diablosport Predator allows the end-user to make the following fine tuning adjustments:
- Idle: Will adjust from -20% to +20%
- Axle Ratio: Can adjust from a 2.xx up to a 6.xx in .01 increments.
- Cooling Fans: Will adjust both ON and OFF in 1 degree increments up/down.
- Power Enrichment (Fuel): Will adjust from -5% to +5% for PE mode
- Spark (Timing): Will adjust from from -10% to +10% for PE mode
- Shift Adaption (duration): Allows user to adjust the time delay during the gear change, i.e. quickness of the shift, from -25% up to +25%
- Shift Points (MPH): Allows user to adjust at what MPH the shift should take place, for each individual gear, in 1 mph increments.
- Shift Points (RPM): Allows user to adjust at what RPM the shift should take place, for each individual gear, in 10 rpm increments.
- Shift Pressure: Allows user to adjust the firmness of the shift action, for each individual gear, from -25% up to +25%
- Rev Limit: Allows user to adjust ON/OFF rev limits, for each individual gear, in 10 rpm increments.
- Wheel/Tire Sizing:
- Factory Wheel Size: Enter the factory tire size in XXX/XX-XX format, i.e. 275/40-17
- Actual Wheel Size: Enter the actual tire size in XXX/XX-XX format, i.e. 305/35-18
The Predator then calculates the difference in overall height for proper speedo calibration.
DiabloSport Performance tunes require the use of Super Unleaded/ Premium grade fuel only, Amoco, Sunoco, or Mobil, if possible.
Diagnostic Capabilities:
- Predator can read and erase fault codes, and contains all the Ford specific P codes.
- Predator diagnostics will work on all 96-03 OBD-II Ford Mustangs or F-Series Gas vehicles.
Live Data Logging and Monitoring Capabilities:
- Predator can monitor over 400 tuning parameters. Please see here for the COMPLETE list: http://www.runninwiththedevil.com/fo...eddiaglist.htm
- Predator can log tune data, at 90 samples per second, for at least a 30-minute period, to be viewed on the Predator screen or be exported to a PC.
Predator Feature Selling Points / Ford Mustang Cobra SVT/F150 Lightning/HD:
- The only flash tuner on the market that allows for end user adjustability to the performance tune, enough adjustment to allow for pulley changes in factory-supercharged engine applications.
- The only flash tuner on the market to accept custom DiabloSport programs, and can be done via using email/internet through your dealer.
- The only flash tuner on the market with advanced diagnostic capability.
- The only flash tuner on the market with data logging and monitoring capability.
- The only flash tuner on the market with a backlit screen, that’s also 300% larger then the competition’s screen.
Get on the Predator waiting list! Email sales@runninwiththedevil.com (please specify which vehicle list you'd like to be placed on, i.e. Cobra, Lightning, Harley, etc.).
Thank you for your time!
Sincerely...
This Thing is gonna be AWESOME
Old Aug 15, 2003 | 10:27 AM
dealerjim's Avatar
It's a great idea but it doesn't look like it'll be coming any time soon. How long have they been preaching "only a couple more weeks" "by the end of the month" "doing some last minute final testing"? C'mon DiabloSport, $hi+ or get off the pot.
Old Aug 15, 2003 | 10:37 AM
lightning1291's Avatar
AMEN
i am on the pre-order list, because they came out here recently and said any day now.... still waiting, but i really want one
Old Aug 15, 2003 | 11:44 AM
captainoblivious's Avatar
Re: Re: Diablosport Predator
...Remember WE ARE NOT TUNERS
Ditto.
Although it would be funny watching people point the finger everywhere but themselves for blowing up their engine.
Old Aug 15, 2003 | 01:06 PM
conleymotorspts's Avatar
If you go to page 328 of the latest summit racing catolog they have the predator for sale at 419.95 part#grn-998517 just a little info
Old Aug 15, 2003 | 02:04 PM
Flying Mofo's Avatar
Banned
I only want one for the DataLogging feature.
But pro-mod hit the nail on the head. 5% is nothing and the scary thing is, youre not even going to know where or when to add the 5% of fuel unless you are on a dyno. IF you are on the dyno, you cannot tell the predator WHERE to add that 5%. Also, timing is another problem. If your chip is file is burned for 16 desgrees of timing, you can only raise that to 1.6 degrees max +/- . That isnt going to make a difference. James at RWTD said he is talking to diablo about this one. You should be given at least a 25% margin of change for timing and 20 - 25% of change for your fuel.
BTW. If none of you have looked into s Mafterburner to richen or lean out your tune in conjunction with your chip, its a good option to consider.
Old Aug 15, 2003 | 04:50 PM
ChildsPlay3's Avatar
While I agree it isnt much adjustability, It better than a Chip or reflash offer. That in itself makes it better than any other product currently on the market.
Peace,
Buzz
