How many lb's should I torque stock pulley to?
Old Aug 14, 2003 | 08:33 PM
mecca's Avatar
Im putting my stock pulley back on. How many lb's should I torque the 14mm hex screw to, and how many lb's should I torque the 2 nuts and 1 bolt for the cage to? Would greatly appreciate your help. Thanks!
-Mike
Old Aug 14, 2003 | 10:23 PM
mecca's Avatar
TTT, anyone?
-Mike
Old Aug 14, 2003 | 10:59 PM
lightningsc's Avatar
specs
specs on stock pulley is 74 ft lbs and the bracket nuts are 34 ft lbs
Old Aug 14, 2003 | 11:06 PM
LatemodelRacer2's Avatar
you selling your truck or going in for a warranty claim?
Old Aug 14, 2003 | 11:27 PM
mecca's Avatar
Selling my truck? You crazy?! Goin in for a warrenty claim. I have a bunch of stuff that needs to be fixed.
Thanks lightningsc. I appreciate it.
-Mike
Old Aug 14, 2003 | 11:45 PM
InS0mNiAc's Avatar
I had the same question Mike but figured that you were like me and would never dream of selling your truck
Old Aug 15, 2003 | 09:23 AM
Speedin Bob's Avatar
From: On the side of the Road attempting to explain 135 miles per hour
Exclamation WARNING
Make DARN sure you use anti-seize on the stock pulley threads as they can be a biatch to remove.
Mine was a LOT tighter than 74lbs. Ended up using a 3-foot cast iron pipe on the end of the socket driver, broke a tooth off the driver, and messed up my back in the process.
Bob
Old Aug 15, 2003 | 03:21 PM
SVT_KY's Avatar
Hand tight on the 14 mm is sufficient ... since it is left handed
that 400 HP engine will tighten it right down ....
Ditto Rabid Robert on the anti seize ... I did mine for warranty
work and after a week it still spun right off with the proper
anti seize.
Old Aug 15, 2003 | 05:55 PM
LightningToGo's Avatar
-Mike
Thank God you'll not selling your L!
Old Aug 15, 2003 | 08:11 PM
mecca's Avatar
Nope! As much as my brother and dad make fun of me, hell no ill never sell her! Just dropped her off at the Ford dealership today for warrenty work, and visited Paul over at REM for about an hour. My buddy with an 03 White L bought some goodies.
-Mike
