What size pulley before chip?
Old Aug 13, 2003 | 09:07 PM
SVTLightning27's Avatar
Question What size pulley before chip?
I have seen some guys on here running 3#s and what have you without a chip. My question is at what point is a chip needed to run a pulley. If i was to go with a 4# pulley would it be recomended to go with a chip?
Thanks,
Kyle
Old Aug 13, 2003 | 09:11 PM
eatoncharged's Avatar
Banned
i dynoed a 6 lower and 2 upper with a 12.9 af if that helps
Old Aug 13, 2003 | 09:26 PM
hslightnin's Avatar
ive been runin a 4#'er for 6k miles no chip no prob
Old Aug 13, 2003 | 11:27 PM
SICKBOY's Avatar
Thumbs up IMO
You can run a 4lber without a chip...but you can optimize the gain with a chip.... that's just my 2 cents
Old Aug 13, 2003 | 11:40 PM
I talked to Justin @ JDM and he said anything more than a 2#er is putting to much strain on the tranny after a while without a chip. Can someone concur with this statement. I would like to know if running a 4#er is alright without a chip and for how long?
Old Aug 14, 2003 | 02:13 AM
hslightnin's Avatar
dont they turn off the boost dump and keep all 8 fireing on the 1-2 shift and up the line presure
i would think that would be more strain but what do i know
Old Aug 14, 2003 | 03:48 AM
Originally posted by John B M
I speak from experience here, I have been running a 6lb pulley for over 12,000 miles with zero problem. I currently have 17,000 miles and still have stock plugs. I have run the truck at over 140mph for long period, I run the truck WOT in -15 degrees and Ive run WOT in over 100 degree weather. I dont know if its good or bad, In my case I havent experienced any bad. My truck has run a best of 12.97@106(Mids 80s) and high 90 high humidity temps runs 13.4s@103ish. The only reason I dont have a chip is, Ive been waiting for the Diablo Predator.
BTW I have verified a/f ratios on a dyno with the pulley.
Eatoncharged- 12.9 is too lean, are you saying you run 8lbs with a chip ?
John,
Your truck sounds really strong! What other mods do you have on it? And what year is your lightning and who did you purchase the 6# pulley from? JLP?
Has anyone else experienced no problems with a 4# pulley or greater?
Old Aug 14, 2003 | 06:40 AM
Six Spd Z28's Avatar
Registered User
Wow....that sounds like my experiances.
(NGK plugs were installed with the pulleys) I ran a 4lb with no chip for 4000 miles , best time was 12.96 @ 106 (60 degree temps) and would run 13.3 @ 102 (90 degrees)
I even ran a 6lb pulley for about 800 miles or so without a chip (no et's)
Had the truck dynoed with the 4lb and the A/F's looked great.
I never put in a chip either because of waiting for the Predator, but I got the KB and a Reflash now.
Old Aug 14, 2003 | 12:55 PM
Pumphead's Avatar
I have been running a 5lb JLP pulley without a chip for at least 11/2 years. My truck is an 01 with 50,000 miles. I have dynoed it 2 times and got a 12/1 A/F both times. As for the trans, I personally like the computer to drop the boost on the shift.
Old Aug 14, 2003 | 01:38 PM
PWR_WHLS's Avatar
4#
4# lower installed - no chip, stock plugs from 25k-30k. Starting running like crap; swapped plugs and problem solved! Drivers side third plug was LOOSE...
Still running REALLY STRONG.
John
Old Aug 14, 2003 | 01:52 PM
rscoleman's Avatar
Disclaimer: results may vary
SVT02 ran a 8# lower and 2# lower, with every other bolt-on, without a chip. This was daily driven, even raced in the winter. Ran a best of 12.2 in January. It wasn't until he took a long trip to his tuners shop that they blew his engine on the dyno burning him a chip. Draw your own conclusions.
I've had the JL 3# for 42k miles with no chip, no problems.
