KB + Mods + Boost = ???
Old Aug 13, 2003 | 05:57 PM
Dan_03Lightning's Avatar
Question KB + Mods + Boost = ???
Calling all KB owners with stock lowers. Please list your mods and boost level with dyno results.
Thanks!
DLM
Old Aug 13, 2003 | 06:34 PM
SVT F15O's Avatar
KB @ 16PSI
Tuner By JDM
Long tubes, high flows, silver bullet.
E-fan, Cobra water pump.
Fluidyne heat exchanger
JDM Phenolic spacer
NGK TR-6's
55LB injectors
ProM Mass air
They achieved over 500RWHP and 600RWTQ but the truck will leave JDM with 496RWHP and 582RWTQ.
-Mat-
Old Aug 13, 2003 | 06:54 PM
Mat
Were the 55lb injectors a critical part to achieving those levels? What brand name chip are you using?
Dan
Old Aug 13, 2003 | 07:17 PM
AZBLACKMONSOON's Avatar
466 hp 546 torque corrected at 14 psi, 437hp 502 torqe corrected at 12 psi, all mods in signature and also no chip ABU2 factory ecm, a/f 12.1
Old Aug 13, 2003 | 08:10 PM
Blue Bolt's Avatar
-Mat- [/B][/QUOTE]
At what boost???
Old Aug 13, 2003 | 08:19 PM
SVT F15O's Avatar
Originally posted by Dan_03Lightning
Mat
Dan
They were to stay safe. The A/F went to mid 13's at the top of the pull. They use Superchips. -Mat-
Old Aug 13, 2003 | 08:20 PM
SVT F15O's Avatar
-Mat-
At what boost??? [/B][/QUOTE]
Same boost levels(16PSI). They made some changes in the chip. -Mat-
Old Aug 13, 2003 | 09:25 PM
Thanks guys, very impressive!
Old Aug 13, 2003 | 11:45 PM
Red BOLT99's Avatar
Stock Block, Stock Tranny and 3:55 gears
KB 17-18 lbs
Swanson Autologic
Swanson Intake
S. PVC fix
LFP E. Fan
Bassani Shorty's
#'s in sig
Old Aug 14, 2003 | 12:55 PM
Redbolt,
what type of tire set up were you using to score a 11.77 that is awesome!
Dan
Old Aug 14, 2003 | 02:23 PM
Six Spd Z28's Avatar
Registered User
I will let you know my dyno numbers in about 2 weeks. I am heading to the dyno on the 30th of this month.
Mine is a stock block, I plan on dynoing with 14, 16, 18lbs of boost.
Old Aug 14, 2003 | 05:02 PM
Red BOLT99's Avatar
I am using 28x10x16 Hoosiers on 16x10 AA's My 60ft was 1.77 at best with lakewood traction bars.
I've since up'ed it to 21-22 Lbs of boost and end up with no traction so I might change rim and tire's to a bigger size. And I've just changed to JLP Bars also and that helped so, we'll see in a couple of weeks what she can pull I'll be sure to post a time.PEASE!
Old Aug 14, 2003 | 05:49 PM
Yeller916's Avatar
dan i checked out your truck yesterday while at REM and its one sweet ride!....it made my black L seem so small and insignificant....good luck gettin her goin!
Old Aug 15, 2003 | 08:41 AM
Yeller
Thanks for the compliments, but I have to say - your L has to be pretty awesome, too. Especially with that juice application.
What were you having done to yours?
Dan
