Transmission Shudder
Old Aug 13, 2003 | 04:38 PM
KEVIND1's Avatar
Unhappy Transmission Shudder
My transmission shudders on mild initial acceleration from dead stop. Dealers says I can't make it fail so here it is back, bring it back if it does it again.
Anyone else have the shudders?
Old Aug 13, 2003 | 04:56 PM
SpankDog's Avatar
Banned
thats a pretty bad explanation, try and explain it a lil bit more in depth such as what speed it happens at and which gear its in.
Old Aug 13, 2003 | 05:41 PM
DR.D's Avatar
My '93 L did that when the fluid needed changing.
Old Aug 13, 2003 | 08:45 PM
KEVIND1's Avatar
A better explanation, O.K., how about from a standstill/stopped at a Stop Sign either turning left or right. Normal acceleration. First gear.
Could it be my rear end causing the shudder?
I've changed the fluids.
Old Aug 13, 2003 | 08:48 PM
KEVIND1's Avatar
Thanks for the replys
Old Aug 13, 2003 | 08:50 PM
SpeedJunkie's Avatar
Dude, you are going to have to give us more to go on!
Old Aug 13, 2003 | 09:16 PM
SpankDog's Avatar
Banned
maybe its the engine hesitating?
Old Aug 13, 2003 | 09:22 PM
Fluid level??
Old Aug 14, 2003 | 12:04 PM
KEVIND1's Avatar
For ****s and grins I've narrowed it down to the differential because it only clicks/shudders when I turn. Long story short ,SVT Central says that there is a friction lubricant that should be added when changing the oil, approximately 3 to 4 ozs., I'm assuming that the Tech didn't add it at the last service at 16,000 miles.
take care
Old Aug 14, 2003 | 02:14 PM
Konig's Avatar
mine "shudderd" sorta speak when I would let off the pedal... once I changed the fluid (as apart of installing my FTVB) it cleared up 100%.... It started the shudder at around 31k miles.
