Changed plugs. What color should they be?
I changed the plugs in my HD last night. It looks as if the truck is running lean. I have been complaining about when I let off the gas the truck seems to defuel and the A/F ratio gauge drops off to nothing, then touch the pedal and it's back up. You can feel the truck like pulling backward, it's weird.
I changed the fuel filter @ 6,000 and again at 9,000 miles. It seemed to help a little. I have a K&N filter w/ stock modded box, Metco idler.
The denso's did seem to inprove throttle response and also the truck now hits 10#'s on the gauge. (More RPM's quicker)
My other problem is the famous oil in intake. The back of the throttle body has it caked on there. The upper phlenum has it all in there too. I'm going to clean the TB tonight and try an set the TPS to see if that may help. It acts as if the TPS is closing the throttle body when I let off the gas. While I'm there I'm going to clean and sand and polish the inside of the upper intake.
Re: Changed plugs. What color should they be?
http://www.ngksparkplugs.com/techinf...200&country=US
Thanks for the link. I feel a little better now, I was worried that it was running lean and I was going to have a major problem when adding my 4# pulley.
I have Denso IT 22's in there now and they are gapped at .035. I had a set of feller gauges last night and was afriad of breaking the tips on the denso's so I didn't want to mess anything up.
